Author Topic: Break in question  (Read 2056 times)
April 04, 2011, 07:25:46 pm
dzlbunny
  • 2
Break in question
« on: April 04, 2011, 07:25:46 pm »
Ok, so I rebuilt my 1.6 NA recently, and I am approaching the 1000 mile "break in" I have put two tanks of fuel through it and got 33 the first and 34 the second. My question is, is this fairly normal for it to be low on mileage and slowly increase after a while, or do i have a major pump or injector problem? Or do I just need to run it a few more mile to find out?? I am fairly new at the whole rebuilt engine thing so any help is much appreciated!!!
Reply #1April 04, 2011, 07:28:24 pm
Re: Break in question
« Reply #1 on: April 04, 2011, 07:28:24 pm »
I would check the timing
Reply #2April 04, 2011, 07:30:29 pm
dzlbunny
  • 2
« Reply #2 on: April 04, 2011, 07:30:29 pm »
Can timing be that far off to effect it that much??? I have no clue??
Reply #3April 06, 2011, 01:09:42 am
Toby
  • 728
« Reply #3 on: April 06, 2011, 01:09:42 am »
Yep. You are at least 10 mpg low if it is in a Rabbit. Check the cam timing first, then the pump.
Reply #4April 06, 2011, 05:29:11 am
« Reply #4 on: April 06, 2011, 05:29:11 am »
My IP bracket loosened up, not all the way but enough to affect timing. I was getting no more than 39mpg. I have 4 tanks on it now since retightening and I have not had less than 42.15. with 2 tanks being 45.5mpg. IP timing is almost everything. Cam, to IP, to Crank timing is more than critical. The IP set to around 1.00 mm is the next step. Finally, if your injectors are not the correct breaking pressure then that will change the actual timing in the cylinder. So make sure it is all good.
