Author Topic: Removing fuel pump for rebuild, Timing?  (Read 2250 times)
April 02, 2011, 10:50:31 am
gabo
  • 26
« on: April 02, 2011, 10:50:31 am »
I am about to remove the fuel pump and need some info on Timing. Is there a usefull link somewhere that could gide me in timing the engine once I put it back on?
'93 Passat GL AAZ Calypso blue!
Reply #1April 02, 2011, 10:54:57 am
coke
  • 254
Re: Removing fuel pump for rebuild, Timing?
« Reply #1 on: April 02, 2011, 10:54:57 am »
You could scribe a mark on the metal in front of the pump body. There should be a line on the end of the pump. Scribe a mark that lines up with that line on the IP bracket itself, and when you put it back on, line it up to that mark. This of course if the vehicle runs fine now and you're happy with where its at.
Reply #2April 02, 2011, 11:07:14 am
« Reply #2 on: April 02, 2011, 11:07:14 am »
Surprisingly enough... the FAQ section.  ;)
