Author Topic: aaz valves and srings  (Read 4260 times)
March 24, 2011, 06:23:43 am
paolomarks
  • 146
« on: March 24, 2011, 06:23:43 am »
Hello, I've got an AAZ out of a 96 golf(Canada)  is it true that the AAZ only had outer valve springs? Mine have no inners.  If needed can I replace them with inners from a 1.6 NA  mechanical head?  Thanks in advance, Paolo.
Reply #1March 24, 2011, 11:08:20 am
Thezorn
  • 381
Re: aaz valves and srings
« Reply #1 on: March 24, 2011, 11:08:20 am »
Mines a 93 AAZ and it has 2 valve springs per valve.
Compounded 93 AAZ
Reply #2March 24, 2011, 03:22:35 pm
Mark(The Miser)UK
  • 1557
« Reply #2 on: March 24, 2011, 03:22:35 pm »
2 springs and identical to the 1.6td ones & n/a ;D
« Last Edit: March 25, 2011, 07:05:17 am by Mark(The Miser)UK »
Mark-The-Miser-UK
Reply #3March 25, 2011, 09:01:45 pm
paolomarks
  • 146
« Reply #3 on: March 25, 2011, 09:01:45 pm »
thanks, for the replies.  Wonder why the PO removed the inner springs?  Any advantage to doing so?  Paolo
Reply #4March 25, 2011, 09:42:24 pm
« Reply #4 on: March 25, 2011, 09:42:24 pm »
Both my AAZ heads only have single springs.
Reply #5March 25, 2011, 09:53:37 pm
« Reply #5 on: March 25, 2011, 09:53:37 pm »
Don't some AAZs have 7mm valves and some 8mm? If that's right maybe the lighter 7mm ones don't need as much spring strength to return it.
Reply #6March 25, 2011, 10:03:36 pm
rallydiesel
  • 1880
« Reply #6 on: March 25, 2011, 10:03:36 pm »
I have a head with 8mm stems and single springs.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #7March 26, 2011, 08:14:19 am
Mark(The Miser)UK
  • 1557
« Reply #7 on: March 26, 2011, 08:14:19 am »
Reading up; AAZ had inner and outer springs, up to 1997ish, then had only one spring, whilst the 1Z and AHU began/carried on the dual spring setup. Code was 028 109 623 A, outer, and 028 109 633A inner, later the single spring was 028 109 623B
Interestingly it seems the AAZ continued to be issued with the dual spring 'carrier'
Finally ABA,and AAC came along with the 028 109 623 'C' outer, no inner
Mark-The-Miser-UK
Reply #8March 26, 2011, 06:22:36 pm
paolomarks
  • 146
« Reply #8 on: March 26, 2011, 06:22:36 pm »
Hey, you guys with the newer AAZ's with only one spring, I'm wondering if your springs have the lower "Carrier" to center and support the spring, like the 1.6's have. My '96 just has the top "carrier", which by the way is the exact same part as the 2 spring models. Why did VW switch to the one spring.?  Don't 2 dissimiler springs reduce vibration because their differing vibrational frequencies tend to cancel out unwanted vibration?.  What do you guys think.?  Paolo
Reply #9March 26, 2011, 06:46:01 pm
rallydiesel
  • 1880
« Reply #9 on: March 26, 2011, 06:46:01 pm »
Mine has a top and bottom spring plate. Wouldn't the spring wear into the aluminum head if there was no lower plate?
Reply #10March 27, 2011, 07:37:56 am
paolomarks
  • 146
« Reply #10 on: March 27, 2011, 07:37:56 am »
Has anyone ever seen a single spring set up without a lower "carrier"?  This is how I found mine, but I have no idea what the PO did.  Thanks, Paolo
Reply #11March 27, 2011, 10:26:14 am
« Reply #11 on: March 27, 2011, 10:26:14 am »
Yup... that's how my single-spring heads are.
Reply #12March 27, 2011, 04:45:24 pm
paolomarks
  • 146
« Reply #12 on: March 27, 2011, 04:45:24 pm »
Great!, Thanks for the help.  Question still remains, though , why would VW switch from  a 2 spring set up to the single.?  Cheaper?  Less reciprocating mass?.
