Author Topic: Break in and head bolts  (Read 3486 times)
March 17, 2011, 12:29:46 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« on: March 17, 2011, 12:29:46 pm »
Well the old Rabbit will be ready for its first start up in a day or two, and I've been mulling over a few things about breaking it in and the final torque on the head bolts. In reading the threads about breaking in, the prevailing opinion seems to be to put the motor to work right away and not let it idle too much. So..... my current plan is to get it started, then jockey the throttle back and forth to keep the RPMs varied until I get it up to operating temparature, then shut it down to do the final torque on the head bolts, and then go about a full break in procedure. Is this the correct way to go about it, or am I off base? Any suggestions appreciated.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #1March 17, 2011, 09:20:22 pm
maxfax
  • 2126
Re: Break in and head bolts
« Reply #1 on: March 17, 2011, 09:20:22 pm »
Usually to get these things up to operating temp you have to rev them up a bit anyhow..   Sounds like you are right on track...
Reply #2March 18, 2011, 01:47:36 pm
DCC
  • 184
« Reply #2 on: March 18, 2011, 01:47:36 pm »
A couple months ago I finished a rebuild of a friend's mk2 and what we did was:
- Start it. Drive around very, very gently, until working temperature.
- Re-torque
- Break in
However, you're quite right on not letting it idle too much. On stops and red lights, change a bit the rpms with small accelerator taps.
Reply #3October 06, 2011, 08:31:12 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #3 on: October 06, 2011, 08:31:12 pm »
Sorry for bringing this topic back from the dead, but i have a question. What did you retorque the head bolts too after getting the engine to operating temp. the first time?
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #4October 07, 2011, 09:50:39 am
« Reply #4 on: October 07, 2011, 09:50:39 am »
im guessing the final 90* turn on the stretch bolts..
Reply #5October 07, 2011, 12:28:46 pm
DCC
  • 184
« Reply #5 on: October 07, 2011, 12:28:46 pm »
Exactly.  :)
Reply #6October 07, 2011, 01:21:49 pm
vdubspeed
  • 191
« Reply #6 on: October 07, 2011, 01:21:49 pm »
I'm about to finish a motor and I wanna make sure I get this correct too.
Bentley list the initial torque. Then you hit it with 1 90degree turn. let it warm up and then turn it 90 again. Do you do the second 90 when the motor is warm or cold?
Sound about right?
Thanks.
Reply #7October 07, 2011, 01:26:49 pm
mtrans
  • 308
« Reply #7 on: October 07, 2011, 01:26:49 pm »
I`ll improve my English
Reply #8November 19, 2011, 12:36:32 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #8 on: November 19, 2011, 12:36:32 pm »
Sorry I didn't answer this right away but I haven't been on board for awhile. After I got the motor up to temp I did a quarter turn (90 degrees) on the bolts. I did it right away, engine still warm, the only time interval was how long it took to get the valve cover off. This is with the 12-point allen type head bolts, just so you know.
            1984 F-250
            1999 Ford Ranger
84 Rabbit
70 Bug
