Author Topic: Garrett GT2056 turbo  (Read 49683 times)
Reply #90May 11, 2011, 05:36:59 am
Alcaid
  • 549
Re: Garrett GT2056 turbo
« Reply #90 on: May 11, 2011, 05:36:59 am »
The TD04-13t-4 might work OK. Used on a 2.5litre 143hp IDI (BMW 525TDS), so should support a 160-170hp IDI if it can give you enough PR to get a Franken to that kind of power levels. Spool would be slower than on the BMW, but should be reasonable especially if gov.modded ;)
'10 VW Passat 1.6TDI Highline
Reply #91May 11, 2011, 06:50:49 pm
« Reply #91 on: May 11, 2011, 06:50:49 pm »
yeah that turbo is the best one of the bunch certainly.  the best thing would be to make a compound setup, maybe a ko3 off a tdi compounded with one of these:
surging could be an issue
« Last Edit: May 12, 2011, 04:25:55 am by Trev0rbr »
Reply #92May 11, 2011, 08:06:36 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #92 on: May 11, 2011, 08:06:36 pm »
You forgot something again :P
Reply #93May 12, 2011, 12:06:22 am
RadoTD
  • 513
    Stage WTF
« Reply #93 on: May 12, 2011, 12:06:22 am »
Dang... anyone have a compressor map for that?
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #94May 12, 2011, 04:26:33 am
« Reply #94 on: May 12, 2011, 04:26:33 am »
i see what i did wrong there
Reply #95May 13, 2011, 07:42:55 pm
« Reply #95 on: May 13, 2011, 07:42:55 pm »
does anyone know much about surge tanks?  where you add volume say twice the volume of the engine to the intake in order to prevent surge.  this was something they did on turbo charged v twin motor cycles because the intake valve is shut for such a long time between the 2 cylinders that the air really had no where to go.
Reply #96May 13, 2011, 08:10:26 pm
« Reply #96 on: May 13, 2011, 08:10:26 pm »
the more i think of it, i do not think this will help to prevent the surge that we fight with a low flow, low rev, low displacement engine, the surge tank would only really help in the v twin situation between intake strokes of the 2 engines.
Reply #97May 14, 2011, 06:39:00 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #97 on: May 14, 2011, 06:39:00 pm »
It appears that the k26-2 will spool the quickest. Alcaid, what do you think about the lag on the td04h-13t?
Reply #98May 17, 2011, 09:45:44 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #98 on: May 17, 2011, 09:45:44 pm »
A stupid though, but a thought still... what about using a BOV? Something that can be calibrated to exhaust extra pressure when the differential is too high but not exhaust pressure when things are going as they should.. what do you guys think about that?
Reply #99May 17, 2011, 09:50:18 pm
Powered by Spearco
  • 1203
« Reply #99 on: May 17, 2011, 09:50:18 pm »
Sounds like a great idea.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #100May 17, 2011, 10:59:54 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #100 on: May 17, 2011, 10:59:54 pm »
I was thinking an EBC to operate the BOV. Not sure if the EBC would take a w terminal signal feed though. that would be the easy idea. If not, a circuit could be fairly easily designed..
Reply #101September 26, 2011, 08:49:25 am
« Reply #101 on: September 26, 2011, 08:49:25 am »
kinda wanted to revive this and discuss some of the new turbos again... i think gt2056 is still a good option for a 1.6td assuming there is good flow in the head and intake manifold surging issues should be minimal
Reply #102March 26, 2012, 02:17:43 am
Alcaid
  • 549
« Reply #102 on: March 26, 2012, 02:17:43 am »
Any news on the GT2056?
