Author Topic: is 48psi possable in 1.9td?  (Read 2906 times)
March 13, 2011, 05:19:24 am
xxkoadyxx
  • 179
« on: March 13, 2011, 05:19:24 am »
like title says, some one i know said there 1.9td they bought for 500 bucks was pushing 48psi, i know this is BS cause a stock motor wouldnt handle it..was he lied to? lol
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #1March 13, 2011, 07:41:12 am
MJF
  • 581
Re: is 48psi possable in 1.9td?
« Reply #1 on: March 13, 2011, 07:41:12 am »
Sure, why not. But where would you need 48psi.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #2March 13, 2011, 08:23:22 am
« Reply #2 on: March 13, 2011, 08:23:22 am »
The motor was prob $500 because they blew it up with 48 psi.. ;)
A stock motor MIGHT be able to handle a spike of that high.. but i doubt it. If it ran that way there is no way it is stock.. Not to mention the stock turbo could simply never move that much air in 5000 rpms of the motor.
Reply #3March 13, 2011, 08:30:41 am
« Reply #3 on: March 13, 2011, 08:30:41 am »
i know someone that used to run 35-40 psi with t3 and k24 turbos on his 1.6td and then later on his tdi-m.  eventually the turbine wheel went flying through down pipe.  i think its possible, but a very very bad idea.  if you can get enough heat blowing out the exhaust you could make 48 psi, but 48psi from the tiny turbo on a 1.9 or even a 1.6 for that matter is not going to put out boost that is going to make power, its going to be hot nasty air, and its going to kill the turbo in short order which could potentially send shards of metal down the intake stream.
Reply #4March 13, 2011, 09:56:38 am
RadoTD
  • 513
    Stage WTF
« Reply #4 on: March 13, 2011, 09:56:38 am »
...which may sound like an awesome thing, but in practicality it actually isn't!
What injection pump does it have? I don't think a 9mm head pump can put enough fuel in to burn 48psi of air so if he had a reasonable turbo setup, it wouldn't necessarily be all that much stress on the engine itself. That being said, it would still take a fair bit to get any turbo spooling that much
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #5March 13, 2011, 10:22:30 am
stewardc
« Reply #5 on: March 13, 2011, 10:22:30 am »
Russell is running that on a VERY modified AAZ, but blew up the previous one at 45psi.
Reply #6March 13, 2011, 10:48:32 am
« Reply #6 on: March 13, 2011, 10:48:32 am »
i heard of a guy a while back.. had a modified AAZ that was running 45 psi. had to have custom machined main caps tho..
that thing i believe was running 45 psi.. the one you looked at, i doubt for a second it RAN at 45psi..
Reply #7March 13, 2011, 10:52:49 am
« Reply #7 on: March 13, 2011, 10:52:49 am »
« Last Edit: March 13, 2011, 10:54:41 am by R.O.R-2.0 »
