Author Topic: 1.6 Compression Specs and question  (Read 20050 times)
Reply #15March 12, 2011, 08:50:56 am
maxfax
  • 2126
Re: 1.6 Compression Specs and question
« Reply #15 on: March 12, 2011, 08:50:56 am »
Too much fuel is what melts things..   Too much boost just plays hell on the head sealing to the block..  Ask Kevin how he knows that..  ;D
Reply #16March 12, 2011, 09:44:07 am
« Reply #16 on: March 12, 2011, 09:44:07 am »
what he said ;D
Reply #17March 15, 2011, 10:57:18 am
silentdub
  • 135
« Reply #17 on: March 15, 2011, 10:57:18 am »
The compression ratio for the 1.6D is 23:1 and the 1.5D is 23.5:1.
There's other option for cams and that's through Giles, they're call high performance but they'll probably get you better mileage too.
Sweet, I'll look in to that. Going to pick up another engine stand today so I can tear it down. Time is really thin with me at the moment.
Who sells cams for the 1.6?
Reply #18March 15, 2011, 11:17:21 am
« Reply #18 on: March 15, 2011, 11:17:21 am »
the quote you quoted, has your answer, lmfao..
Giles is his name BTW..
Reply #19March 15, 2011, 10:57:41 pm
mystery3
  • 774
« Reply #19 on: March 15, 2011, 10:57:41 pm »
I was old anything over 6lbs boost on an NA engine will melt the rings. Anyone confirm?
How can you tell the rings melted when they're fused with all the surrounding bits?
Reply #20March 16, 2011, 12:55:33 am
maxfax
  • 2126
« Reply #20 on: March 16, 2011, 12:55:33 am »
Typically the rings don't melt first, the piston does..   You'll be able to see obvious damage to the piston..
Reply #21March 16, 2011, 03:11:39 am
regcheeseman
  • 714
« Reply #21 on: March 16, 2011, 03:11:39 am »
Quote from:  R.O.R-2.0
but i can tell you its un-true as hell.. i run around 20 psi to my n/a all the time.
Do you run squirters in this motor, I'm asking because of my knocking TD that has just been installed and the previously fitted perfectly good NA is sat on the floor. I've not used the NA because of the lack of squirters.
Reply #22March 16, 2011, 07:21:09 am
silentdub
  • 135
« Reply #22 on: March 16, 2011, 07:21:09 am »
Sorry, I never heard og Giles and I was looking for a link. I'll google it.
thnaks!
Reply #23March 16, 2011, 07:27:46 am
silentdub
  • 135
Reply #24March 16, 2011, 08:26:34 am
« Reply #24 on: March 16, 2011, 08:26:34 am »
im running a n/a.. (it came out of a vanagon, and they NEVER came with turbos that i know of.)
if it had squirters, i would call it a TD..
its a 11mm n/a block.. stock fiber head gasket..
the key to not burning these engines down, is not about keeping low boost, its about keeping the fuel in check with the right amount of air. thats why i can get away with 20+ psi.. i have enough air in there to keep the burn nice and lean.
Reply #25March 16, 2011, 12:49:14 pm
« Reply #25 on: March 16, 2011, 12:49:14 pm »
Yup they did, look on ebay, someone usually trying to sell a TD vanagon engine.........
Reply #26March 23, 2011, 10:36:33 am
silentdub
  • 135
« Reply #26 on: March 23, 2011, 10:36:33 am »
Well, I'm encouraged now..... after some reading I see that this motors are soolid for the most part.
Can't wait to rebuild this little guy.
Reply #27March 23, 2011, 10:44:27 am
« Reply #27 on: March 23, 2011, 10:44:27 am »
theres someone on craigslist selling a TDI-m from a vanagon..
and i meant that MY engine never came with a turbo..
its a CS code engine.. not turbo'd
Reply #28March 23, 2011, 06:24:45 pm
sdwarf36
  • 159
« Reply #28 on: March 23, 2011, 06:24:45 pm »
FYI-surfacing the head will raise your compression ratio zero-its already flat. And if you surface the block .010 (DON"T!) you would only be raising CR by maybe .2.(21.0 to 21.2) And your piston + valves are closest at (apx) 8* before tdc for the exhaust-and (apx) 8* after tdc for intake.
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
