Author Topic: Garage clearout (engines - 1 MTDI, 1 IDI)  (Read 4097 times)
March 07, 2011, 12:59:18 pm
alphawerks
« on: March 07, 2011, 12:59:18 pm »
Hi,
I'm trying to judge interest in two setups I have.
MTDI
The first  powertrain was collected to install in my wifes beetle but the plans have changed:
It is an ALH tdi with a single mass flywheel, MK3 tdi gearbox and an Mtdi pump (10mm). (I used this spec pump on a MK3 golf and I seemed to be in the 120 hp range with a garret t2 @ 15 psi) At the moment it has a VNT15 turbo.
I could include either MK2/3  or MK4 mounts.
HG, cambelt and WP are all good and changed in the last 10K km.
Alternator / PS pump not included.
*I will only sell after bench testing the engine to make sure all is well - I am not interested in problems.
Would like to get $1500cad.
IDI
The second is a 91 jetta 1.6 td with the garret turbo, O2a gearbox from a passat, and a Maxed pump using a 1.9 camplate with Governor mod etc.
Alt and PS pump included, no starter.
About 30k km on the timing belt and Pump reseal.
Was used in a Passat conversion, now parked.
Started well and gave good milage (4.1 l/100km when REALY trying), Was fast in the MK2 it came out of (Would walk away from a V6 audi), In the passat it was similar to the 16v (ho-hum).
HG should be changed as it leaks oil.
Can include Hyd clutch and cable shift box if required.
This complete engine/trans was parked running and will run again easily, but HG should be changed.
Would like to get $400cad for complete engine and trans.
I am located in Ottawa Canada, and would ship within Canada (pick-up prefered). If the buyer would like to arrainge shipping to the states I'll try to help.
« Last Edit: March 08, 2011, 04:56:26 am by alphawerks »
Reply #1March 08, 2011, 07:30:27 pm
bvanetten
  • 70
Re: Garage clearout (engines - 1 MTDI, 1 IDI)
« Reply #1 on: March 08, 2011, 07:30:27 pm »
I'd be all over one or both of those motors if you were closer.  Shipping to Phoenix would be a deal breaker.
Reply #2March 09, 2011, 04:02:56 am
ilikevwdiesel
  • 1202
« Reply #2 on: March 09, 2011, 04:02:56 am »
pm sent, you can just email me if you like: ilikevwdiesel at yah00 d0tc0m
My Bio
Reply #3March 10, 2011, 10:35:18 am
trav1856
  • 230
« Reply #3 on: March 10, 2011, 10:35:18 am »
Yeah I'd be all over that too, shipping would kill to Oklahoma as well.
1981 Rabbit Diesel
1981 Cabriolet
