Author Topic: WTB split waterpump pulley and shims for Quantum/Audi1.6td  (Read 4359 times)
February 27, 2011, 07:56:31 pm
tdihuntdawg
  • 27
« on: February 27, 2011, 07:56:31 pm »
pulley # 068 121 029a ,shims # 068 121 185b
Reply #1February 27, 2011, 10:24:07 pm
Quantum TD
  • 1195
Re: WTB split waterpump pulley and shims for Quantum/Audi1.6td
« Reply #1 on: February 27, 2011, 10:24:07 pm »
I should have a spare one. Let me check.
Reply #2February 28, 2011, 06:14:35 am
« Reply #2 on: February 28, 2011, 06:14:35 am »
I need the same... If you have extra.
Reply #3April 03, 2011, 09:02:25 pm
kevo
  • 30
« Reply #3 on: April 03, 2011, 09:02:25 pm »
me three... please PM if you've got one to sell.
Reply #4April 04, 2011, 03:43:31 pm
Quantum TD
  • 1195
« Reply #4 on: April 04, 2011, 03:43:31 pm »
Hmm. I pulled my pulleys  off my 1982 Quantum, and mine didn't have the shimmed pulleys on the WP. The crank pulley was shimmed. The setup looks like what was used on 1980-1984 Rabbit, Convertible and Scirocco GASSERS with AC. In fact, the part numbers are exactly the same: 055 --- --- numbers.
Another option to consider is the 1997-1998 Passat AEB 1.8T setup. It runs off the P/S pump and is a split design, without shims.
What's the application going on? I've seen some posts by Andrew, without mention of the application.
Vanagon? I've seen Andrew mention flipping them around for offset, so I don't know if the Passat setup will work on the (custom) application.
Reply #5April 04, 2011, 06:38:02 pm
tdihuntdawg
  • 27
« Reply #5 on: April 04, 2011, 06:38:02 pm »
When I started this request it took a while to get any response so I went to the u-pull it and bought a couple of 2.0 w.p. pulleys with the same pilot l.d. I then machined a aluminum spacer and shims on my lathe. Does any body have the link on how to post pictures.
Reply #6April 07, 2011, 10:33:34 am
danster
  • 71
« Reply #6 on: April 07, 2011, 10:33:34 am »
Audi 1.6TD, Is this the type of car in question?
I parted this car a while back and have the waterpump pulley with 5 shims. And pretty much all those boost pipes and airbox too.
UK based though.
Reply #7April 07, 2011, 09:37:39 pm
Quantum TD
  • 1195
« Reply #7 on: April 07, 2011, 09:37:39 pm »
Did that thing have an intercooler?  :o
Reply #8April 08, 2011, 03:05:45 am
danster
  • 71
« Reply #8 on: April 08, 2011, 03:05:45 am »
Yes, it sure did have an intercooler, (not very big though). It is quite a bunch of bananas all the hoses make.
Also has watercooled turbo and a temprature controlled electric auxiliary coolant pump for circulating the coolant through the turbo after engine is switched off.
« Last Edit: April 08, 2011, 03:07:33 am by danster »
