Author Topic: Off topic, but migth be of interest to some......  (Read 4833 times)
February 24, 2011, 03:33:06 pm
Patrick
  • 1034
« on: February 24, 2011, 03:33:06 pm »
I've got an old Bobcat with an air coooled 4 cylinder wisconson engine.
Died on my wife the other day, she was cleaning snow at home while I was doing it at work.
A little investigation showed no spark. Old style points ignition, haven't worked on one in a LONG time.
Figured out the spring that makes teh points make contact was broke, so it looked like an easy fix. Had to pull the distributor to get at it, marked everything so I could put it back together. Went to the box of parts that came with the machine, found 1 condenser, three sets of points, 2 caps, 3 rotors. Put a set of points and condensor in it, set the gap to spec, and put it all back together.
Still no spark.
To make a long story short, points are just a ground that's timed. THEY WEREN"T GROUNDING! NEW POINTS!
Had to take  (after removing the distributor again and using an ohmeter to see if they were doing thier job) sandpaper to a brand new set of points to make them make a good contact.
Put it back in, machine fired up on the first rev.....
Frustrating! Don't take for granted that new parts (Delco no less) are going to work. Check it!
Reply #1February 24, 2011, 03:36:30 pm
truckinwagen
  • 1895
Re: Off topic, but migth be of interest to some......
« Reply #1 on: February 24, 2011, 03:36:30 pm »
that is precisely why points are no longer used in new motors...
-Owen
83 Opel Kadett Diesel
Reply #2February 24, 2011, 09:16:04 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #2 on: February 24, 2011, 09:16:04 pm »
I always used to stick a fingernail file in there for a few strokes to make sure they had a good clean contact surface. Like you it's been a long, long time since I worked on anything with points.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #3February 24, 2011, 09:26:31 pm
maxfax
  • 2126
« Reply #3 on: February 24, 2011, 09:26:31 pm »
I've had that happen a couple times with points that I've had sitting around for a long time.. (My golf cart still uses the darned things  :-\)  But of course with points, it's always best to have that spare set around.. I've been scarfing the little packages of desiccant they put in with electronics and such and throwing them in some tupperware with my points for storage...
But then again, with the quality of new and reman parts now days, I'm totally unsurprised when I get something that doesn't work.. Sometimes twice...
« Last Edit: February 24, 2011, 09:31:34 pm by maxfax »
Reply #4February 25, 2011, 11:13:34 am
Dakotakid
  • 1240
« Reply #4 on: February 25, 2011, 11:13:34 am »
I still run points in XT and TT 500 Yamahas. I much prefer the points over the CDI unit in, yet, another XT 500. The CDI ALWAYS requires a maximal kick to make ignition happen. The points will go with a slight kick instead.
All this matters with age-related cartilage in the knee and hip! :'(
Reply #5February 25, 2011, 01:01:20 pm
« Reply #5 on: February 25, 2011, 01:01:20 pm »
gotta do whatever it takes to make them thumpers easy to start..
