Author Topic: The age old "I Want to TD my N/A" Type question  (Read 5854 times)
Reply #15February 23, 2011, 05:31:23 pm
Re: The age old "I Want to TD my N/A" Type question
« Reply #15 on: February 23, 2011, 05:31:23 pm »
I think stock 1.6 TD has like 72-75hp and 98-101tq. 80/144 will be a bit more of a challenge... Bigger cold air intake, big exhaust (2.25"-2.5") with no muffler, lotta fuel, and more boost. But... More heat will come from that... I think a 1.6IDI TD in a 2400+ (???) Car will be deathly slow. I just tore a td out of an mk2, and even in that shell it was a slug.
Reply #16February 23, 2011, 07:58:09 pm
« Reply #16 on: February 23, 2011, 07:58:09 pm »
Well Andrew I can only assume you have done a butt-ton of mods to that engine when you say well-suped. I don't think a stock 1.6TD with an inter-cooler will be a performer in a heavy vehicle. Still pretty sluggish in stock form in my 84..
Reply #17February 24, 2011, 07:41:22 am
« Reply #17 on: February 24, 2011, 07:41:22 am »
ive never seen a 1.6 with a torsional vibration damper.. (someone correct me if im wrong)
only the audi 2.0 5 bangers, and the AAZ.
All 1.6TDs that I've seen came with one.
ok, then what is it? its supposed to be a harmonic balancer isnt it?
all ive ever seen is the 1.6's with a pulley on the crank sprocket..
Reply #18February 24, 2011, 08:27:43 am
Wayland
  • 364
« Reply #18 on: February 24, 2011, 08:27:43 am »
Yes, it's a harmonic balancer. Stock on all 1.6TDs.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #19February 24, 2011, 12:25:37 pm
Bugsy_malone 666
  • 178
« Reply #19 on: February 24, 2011, 12:25:37 pm »
yeah what I dont want is to pitching the wrong odds on my engine, I have a 1.8 petrol which isnt mustang fast but its not bad, so to stick in a Diesel, it could do with a bit of poke.
Its a shame 1.9TD lumps seem to go for so much money.
I mean basically What I see is an engine that I dont really want to waste, I'd rather not sell it off cheap or throw it away if for minimal spend some improvements can be made to make something equal to my 1.8 petrol engine.
The current 1.8 petrol is 90bhp @5500rpm & 107lb.ft @2500rpm with a 12.1 0-62mph time. Unladen weight (5door) 2348lbs/1065kg
The 1.9 diesel came in diesel/TD/TDi with these specs:
1.9 - 64bhp/91lbs.ft  17.6 0-62mph
1.9TD - 75bhp/110lbs.ft   15.1 0-62mph
1.9TDi - 90bhp/149lbs.ft    12.8 0-62mph
so basically my mk3 golf has some figures which I would like to retain. The 1.4TDi in my dads Seat is 79bhp/144lbs.ft and that car weighs about the same as my golf, but the 1.4TDi is a really expensive engine for a 'project'!
Judging by the figures there is no way I can go diesel without losing performance, unless I can crack the power output of the 1.9TDi, in which case I may as well just put a TDi in!
The stock 1.6 NA is like 54bhp and around about 64lbs.ft of torque or something daft, its a really lazy engine!
Anyway enough of the stacking the odds against my idea, now its time to overcome the problems.
So we start with a 1.6NA, put a turbo on it but heat might be a problem. Will Piston oil squirters give me a good helping hand with this? Whats the best way to fit them? is it a total engine strip down or can it be done by means of just removing the sump? to much swarf I guess from the installation. I have also heard of people installing different types, there seems to be ones which have 2 holes to install, 1 for the squirter tube, the 2nd for a clamp, then there are also ones which just seem to screw in?(are they a banjo bolt type thing?)
Oil pump I will be fitting is one from a TD 1600 so oil pressure shouldnt be an issue (as currently it has a Vanagon Diesel oil pump)
Obviously a big intercooler to cool inlet charge air will also lower heat issues with the engine. Now as previously mentioned too big may create lag, but will it be a massive amount? the cooler I have is about 2ft square and 1" thick so can sit infront of the radiator easy enough.
I have a K&N panel filter which I hope will be enough for the Turbo to easily draw through.
I was thinking of mostly using the stock petrol exhaust syste, taking the CAT convertor out and replacing it with a bypass tube, but then there are 2 rear silencers, the end one is a 'sporty' unit slightly more free flowing than a stock one, then there is a stock mid one. Pipe work is 2" end to end pretty much.
I guess the final things really is the fuel pump thing, it was mentioned that the thingy turbo diesels normally have on top (a barnicle?) is for fuel system advance, so surely while I apparently can get away without having one, it would be better to run with one for acceleration reasons?
Its fairly tempting to just bung a VR6 in but this needs to be insurable for the G/F lol and as shes at university, I figured a decent diesel setup would work to her advantage not having to put fuel in so often!
Reply #20February 24, 2011, 01:22:51 pm
Bugsy_malone 666
  • 178
« Reply #20 on: February 24, 2011, 01:22:51 pm »
An intercooler, 14psi of boost, fuel to reach a max of 1,200° and a free-flowing 2.5" exhaust will get you performance above that of the 1.8 (90hp, 107tq).
You can't really add the squirters without pulling the engine apart.  Along with the squirter installation in the block you also need to use TD pistons or notch the non-turbo ones and I can't imagine how you could do that with the engine in place without creating horrendous amounts of metal bits in the engine.
I would never use a K+N filter on any engine of mine.  They do not filter well enough.
I know why you dont use K&N filters on new cars, the oil filtration knackers Airflow sensors! but on an old diesel it will be fine :) They filter 'ok' but I definately dont think they are a lifetime product like they say they are, I think at the time 5 years ago however there wasnt much in the way of other stock replacement panel filters available at the price. The foam 'Ramair' panels are better, VW even use the foam ones in volkswagen motorsport!
I'll have to look at rebuild costs as I think it probably can hurt to check it all over, but I am of the opinion if its not broken and works fine how it is, dont take it to bits because you can guarentee it will never be the same again! I think I have heard about notching the pistons as well. If I could get another 1.6TD as cheap as what I bought for my bus would be so easy, but that was a in the right place at the right time situation!
So I guess its time to look on ebay for EGT gauges and a rebuild kit for my Garret GT15 turbo! Not sure it will do 14PSI or not, I think it was 7-9psi when used on the 1.7TD it came off.
Something I have noticed while on ebay tonite is the fact that Peugeot use bosch injector pumps on their Turbo Diesels but they dont have the fuel advance barnicle on the top, its just a standard pump!
I have never known of a slow peugeot!
