Author Topic: The age old "I Want to TD my N/A" Type question  (Read 5872 times)
February 22, 2011, 04:12:03 pm
Bugsy_malone 666
  • 178
« on: February 22, 2011, 04:12:03 pm »
Well I hope I dont get to much of posting this thread as I think it has been covered before and I have lurked around reading the forum a bit before managing to register to clear up what to do.
Basically I have a lowish milage 1.6 N/A with what looks like a recon stock fuel pump for an N/A. Originally I ran this in my baywindow camper before picking up a cheap TD and it was pretty slow at like 54bhp(?) so anyway I have had the engine kicking about for a while and wanted to do somthing useful with it, its currently bolted to a Vanagon/T25 slanted sump that puts the engine at 50degrees, so I do have a chance to have a look inside without to much distrubance but i suspect I wont find much of usefulness in there!
I also have a 1.8 mk3 golf driver which I have had for years and I think its kinda come to the end of its first life, its served me well but I just got a mk6 golf TDi (with a 1600TDi!) and thought maybe a TD conversion on my mk3!
So the 1600 N/A will run on Veg oil which is one requirement, but I need to look at turbo options.
I have a garret T15 turbo which came from a 1.7TD engine (Vauxhal/opel 1997 1.7DTi GM engine?) it needs a bearing set which i have seen on ebay cheap and though ok what else do I need to make it a TD.
Presumably I can get a TD fuel advance barnicle(is that what its called) from any other bosch TD pump and stick that in place of my current top for turbo fuel advance? are there any other things to change here?
so if thats a suitable turbo and the fuel advance top is an easy swap, what about injectors? are the 1.6 NA/TD ones the same?
Piston squirters seem to be something that come up fairly regular to stop the engine eating itself, so I am wondering how needed are they? I dont want to kill a perfectly good engine due to my heavy driving style (I am suprised the mk3 1.8 is still great at 120k considering it sees 6k rpm regular!), what I want is a turbo diesel using stuff I mostly already have without the investment of another engine that I can get maybe 70-90bhp out of (and who knows what torque) so that it at least drives as well as the petrol engine thats in there.
I do also have some intercoolers kicking about, one about 12" long 3" deep by 10" wide with a thermostatic valve for warm up inside of an old Renault 5 Turbo and I also have a volvo intercooler thats about 2ft square but only about 1" deep, I thought this might also be useful as I have heard bringing induction air temps down can stop the engine from eating itself so quickly.
I mean my dad has a 1.4TDi Seat (basically a polo) and that thing really puts you in your seat for 70-80bhp, yet my 90bhp mk6 golf just doesnt!
So I guess I want to be able to feel turbo pull, but my base engine is a 1600 NA.
The only other thing is are solid valve lifts ok? earlier engines seem to have them but most of the TDs seem to be hydraulic? or is there an easy retrofit proceedure(most people will say bung a 1.9TDi head on)
So what can I do, are my plans pretty sound or are there things I have forgotton? Just looking for a generally budget based conversion and not looking for hotrod performance, more matched performance with the ability to run on vegetable oil to make driving cheap and fun in a modified mk3 :)
Reply #1February 22, 2011, 04:25:07 pm
ktownboostn
  • 31
Re: The age old "I Want to TD my N/A" Type question
« Reply #1 on: February 22, 2011, 04:25:07 pm »
I converted my old 4-door from n/a to TD. Used a AAZ head,pump and injectors, T3 and mani, ME intake mani. ran @ 15psi and other then the fact that the motor was in need of rings from the beginning( had a spare 1.6TD block that i was starting to rebuild )... it was reliable and took a beating like a champ
2001 VW Jetta 24v VR6 - Rally Car
1990 VW Jetta AAZ/MF - Daily coal roller
1986 VW Cabriolet 12v VR6 - Project car
Reply #2February 22, 2011, 05:09:50 pm
« Reply #2 on: February 22, 2011, 05:09:50 pm »
I think there are only two things that need to be taken in to account when putting a turbo on an N/A engine...
The block from what I recall (once was looking in to the prospects of turboing an n/a, but now im going TDi lol) the blocks are the same with regards to the piston squirters.. I mean they are a nice upgrade, but entirely necessary? No. Will you be running the engine at 1250F all the time? There have been N/a engines with a modded pump withstand the temps just as easily as a TD motor. Obviously without them you won't be able to beat on it quite as hard, They aren't really even really good until stuff starts getting REALLY hot.. Keep the fuel moderate for power and not billowing like a freight train and you'll be ok. The head is also identical aside from sodium filled exhaust valves, and possibly different pre-cup? I think i may have read that somewhere.
Is this engine Mechanical? I think I read you referencing solid lifters? shouldn't matter really, as there were mechanical 1.6TD's from the factory.
The engine will love an inter-cooler, not too big or it will really lag boost building up.
The pump head should also be able to be swapped over.
In summary, Many have successfully put turbo's on n/a's with with ZERO modifications and came out fine. There is a member on here R.O.R.2.0 who turboe'd the crap out of a stock 1.5n/a motor, and it did fine. He's around 23-25 so you know it was beaten on too. ;)
Reply #3February 22, 2011, 06:16:41 pm
« Reply #3 on: February 22, 2011, 06:16:41 pm »
honestly, if i had an na diesel and i wanted to turbo it, i would just turbo it, i wouldn't get a td pump cause they don't put out any extra fuel,  like everyone has says, just watch your egts because of not having sodium filled valves they do no dissipate the heat as quickly so they will become burnt and warped much more easily.  as far as the piston squirters,  i really do wonder how much difference they truly make.
Reply #4February 22, 2011, 10:09:17 pm
rdezsofi
  • 19
« Reply #4 on: February 22, 2011, 10:09:17 pm »
I would think the solid lifter heads would be better suited to a turbo set up. The hydraulic heads use a lot of oil pressure, and having solid lifters free's up a lot of pressure for a turbo. (In theory, the turbo should last longer with higher pressures and cooler oil.) EGT's are what to watch for. I heard the turbo motors had forged crankshafts vs the NA's having a cast crankshaft. ....Not entirely sure that's accurate though.
Reply #5February 22, 2011, 10:55:16 pm
mystery3
  • 774
« Reply #5 on: February 22, 2011, 10:55:16 pm »
What are the kerb weights of these vehicles? Would I be wrong in thinking the mkVI golf might weigh nearly twice the polo/ibiza?
Reply #6February 23, 2011, 08:02:03 am
« Reply #6 on: February 23, 2011, 08:02:03 am »
ive never seen ANY vw with a cast crank shaft.. not a gasser, let alone a diesel..
im not going to say they never did, but im 99% positive that diesels ALL got forged bottom ends..
and as someone was talking about the n/a pump and injectors, yea, they work fine as long as you tune your pump right..
ive been running a n/a pump and injectors on my engine for lots of miles now.. the n/a pump gives better bottom end power.
Reply #7February 23, 2011, 10:48:55 am
JerryGTD
  • 89
« Reply #7 on: February 23, 2011, 10:48:55 am »
Lots of good info can be found here:
http://www.4crawler.com/Diesel/SAE/vwtdsae.shtml
1991 Jetta GL ECOdiesel
Reply #8February 23, 2011, 10:53:46 am
coke
  • 254
« Reply #8 on: February 23, 2011, 10:53:46 am »
From the SAE paper re: 4 cylinder turbo diesel used in VW
A number of changes were made to the crankshaft. The front end of the crankshaft was reinforced. The highly loaded crank-pin, at cylinder 4, has its radius induction hardened and the oil hole ground while radii at the other pins are roll-hardened. A torsional vibration damper is used.
Reply #9February 23, 2011, 11:07:24 am
« Reply #9 on: February 23, 2011, 11:07:24 am »
im sure that its talking about the AAZ tho..
no 1.6 diesels came with a harmonic balancer.
Reply #10February 23, 2011, 11:30:54 am
coke
  • 254
« Reply #10 on: February 23, 2011, 11:30:54 am »
The SAE paper doesn't cover AAZ. Only the 1.6L TD, and the 5 cylinder TD used in Audi.
« Last Edit: February 23, 2011, 11:33:41 am by coke »
Reply #11February 23, 2011, 01:30:58 pm
« Reply #11 on: February 23, 2011, 01:30:58 pm »
ive never seen a 1.6 with a torsional vibration damper.. (someone correct me if im wrong)
only the audi 2.0 5 bangers, and the AAZ.
Reply #12February 23, 2011, 02:19:39 pm
Bugsy_malone 666
  • 178
« Reply #12 on: February 23, 2011, 02:19:39 pm »
Wow! you guys have been really helpful inside of my first day on here!
Its unusual that I get such a decent solid response when posting and idea I had on a forum, so many times I have gotton ripped off a right stripe and told 'why bother, put a 1.9 in it'
This is cool, so what we have basically said is I need to get new bearings for my turbo, bolt it on and add a tiny bit more fueling, then spend my money on an EGT gauge and just dont give it death all the time :)
with regards to the weight thing I did a bit of reasearch:
2008 seat Ibiza =
1075kg kerb weight
144lb/ft torque
79bhp(80ps?)
0-62mph - 12.8 seconds
2009 mk6 Golf =
1268kg unladen ( think that counts as curb weight?)
170lb/ft torque
89bhp (90ps?)
0-62mph - 12.9 seconds
so I am a bit confused as you why I dont feel the pull! in theory with the same 0-62 time you'd expect it ( I mean 0.1 sec is hardly going to make a big difference)
The mk3 I am putting it in on the otherhand is around 1300kg (cant find specific weights) which means 90PS is probably what I need to aim for.
So I guess now I just need to make up the flange to take my turbo and rebuild it :) then I'll need a Diesel gearbox as I dont think a petrol one is going to be what I need!
The other question is by just whacking a turbo/intercooler on would at least 80bhp/144lb/ft be fairly easy to accomplish?
Cheers guys :)
Reply #13February 23, 2011, 04:13:39 pm
« Reply #13 on: February 23, 2011, 04:13:39 pm »
a harmonic balancer came on my 1.6td engine
Reply #14February 23, 2011, 05:14:20 pm
Wayland
  • 364
« Reply #14 on: February 23, 2011, 05:14:20 pm »
All 1.6TDs that I've seen came with one.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
