Author Topic: Where To Buy Exhaust Flange-K14? Downpipe Making  (Read 7528 times)
February 21, 2011, 02:50:20 pm
jasonsansfleece
  • 162
« on: February 21, 2011, 02:50:20 pm »
I want to make a 2 1/2" down pipe for a K14 turbo in a mk2.
A couple of questions;
Can I make this out of 16g mandrel bends, SS or mild steel? Tig welded.
Where can I find a ready made flange or do I need to make/have made one?
Reply #1February 21, 2011, 03:06:17 pm
Reply #2February 21, 2011, 03:29:27 pm
jasonsansfleece
  • 162
Re: Where To Buy Exhaust Flange-K14? Downpipe Making
« Reply #2 on: February 21, 2011, 03:29:27 pm »
Thanks Vince,
I have since found out (all by my self ;D) that Techtonics sell a flange in mild steel and that ATP Turbo have flanges in SS and mild.
Having a hard time getting a streight answer out of ATP though.
Take a look at this one.
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-FLS-032&Category_Code=ATP-FLS2
Searching through these forums, this part had been used with a garrett T3.
Is the down pipe flange bolt pattern the same as a K14?
Did VW make different DP's for T3's and K14's?
Reply #3February 21, 2011, 03:43:28 pm
« Reply #3 on: February 21, 2011, 03:43:28 pm »
Yeah, it's a bit confusing... but the T2, T3, and K24 flanges are all the same square 4-bolt pattern... so if you find one you've found them all.  I got mine off eBay the last time actually.
The K03 found on early AAZ engines is the only weirdo flange.. sort or a rectangle with room for the wastegate to vent.
Reply #4February 21, 2011, 10:26:46 pm
AudiVWguy
« Reply #4 on: February 21, 2011, 10:26:46 pm »
I would recommend using 3" for the down pipe, I felt like it has faster spool-up and lower EGT's than the 2.5".
Just my 2 cents.
-JB
Reply #5February 22, 2011, 04:09:19 am
jasonsansfleece
  • 162
« Reply #5 on: February 22, 2011, 04:09:19 am »
Well, it does not add much to the cost of materiels to go 3".
1.57" extra weld per joint ;D
I would assume SS to be the better materiel, unless someone has another opinion?
Reply #6February 23, 2011, 08:18:43 pm
AudiVWguy
« Reply #6 on: February 23, 2011, 08:18:43 pm »
Would not the total length from the downpipe to the end of the pipe out the rear be shorter on the vanagon because the engine's in the back in comparison to a front engine car?
although, I can't argue with your comparison of no exhaust to exhaust. I just felt that the larger exhaust allowed less back pressure and lowered my EGT's at both cruzing and full throttle.
It is harder to fabricate 3" but in my case I felt it was worth it. (Or maybe I have some miss-guided fixation that bigger is better, lol) :o
Cheers,
-JB
Reply #7February 23, 2011, 09:40:15 pm
« Reply #7 on: February 23, 2011, 09:40:15 pm »
Biggest is usually not always the best.. bigger yes, but not biggest possible. 2.5 inch is plenty less back pressure then what was there stock. Too big and it will loose velocity going through the tail pipe, and actually be counterproductive. Like a 3inch on a 1.6L engine. little unnecessary, when cummins boys are running 3.5-4.5inch exhausts, and then the motehr of all.. 5inch mandrel bent SS.
2.5inch is more than adequate.
Reply #8February 24, 2011, 05:46:32 am
« Reply #8 on: February 24, 2011, 05:46:32 am »
http://weirtech.ca/catalog/index.php?cPath=13_17
There is more than that on the site if you look around.
