Author Topic: Crank Pulley Bolts  (Read 4786 times)
February 21, 2011, 07:26:48 am
jaysen71581
  • 211
    Hagerstown, MD
Crank Pulley Bolts
« on: February 21, 2011, 07:26:48 am »
Trying to remove the 4 bolts that hold on the crank shaft pulley, got the first 3 bolt out, went to get that last one and the bastard rounded out on me, i did the pb blaster over night, along with the tapping of the hex socket in, anyone have a good fix for this??
Reply #1February 21, 2011, 07:49:31 am
rdezsofi
  • 19
Re: Crank Pulley Bolts
« Reply #1 on: February 21, 2011, 07:49:31 am »
If you can't grab it with a quality vice-grip and get it to loosen.....use a die grinder to remove the head. Once the pulley then comes off, you should have enough room to use the vice grips to twist out the remains. If you still can't get it out at this point, just replace the gear....
Reply #2February 21, 2011, 07:49:52 am
coke
  • 254
« Reply #2 on: February 21, 2011, 07:49:52 am »
Pound the next largest size bit into the head with a large hammer, and take it out.
Or, you can use a dremel and cut a slot through the bolt that a flat tip screwdriver with a large end will fit in, and use vice grips on the screw driver to turn it loose. Had good luck this way too.
Reply #3February 21, 2011, 08:19:06 am
« Reply #3 on: February 21, 2011, 08:19:06 am »
If you could pound that next largest one in possibly a SAE instead of metric socket bit and use an impact to reverse it that usually helps. You hate to but sometimes an air hammer/chisel is the answer.
Reply #4February 21, 2011, 08:22:07 am
« Reply #4 on: February 21, 2011, 08:22:07 am »
just drill the head off the bolt then twist out the rest with your fingers..
Reply #5February 21, 2011, 08:40:50 am
410
  • 581
« Reply #5 on: February 21, 2011, 08:40:50 am »
Also a 12mm 12 point socket will pound onto the bolt head and bite enough to get it off.  Works almost every time.
Reply #6February 21, 2011, 08:56:03 am
GEE-BEE
  • 1604
« Reply #6 on: February 21, 2011, 08:56:03 am »
We need someone to stock ARP 12pt 8 x45 mm Bolt's for this application..
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #7February 21, 2011, 08:59:14 am
BigVWman
  • 332
« Reply #7 on: February 21, 2011, 08:59:14 am »
i use an air chisel and try to catch it on an angle, the vibration usually helps break them loose! just don't slip off!
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #8February 21, 2011, 09:10:25 am
« Reply #8 on: February 21, 2011, 09:10:25 am »
GB
Not ARP but I got them. Also, in stainless, but I am pretty sure that there are a couple different crank pullies and bolt lengths. No bother to me, I should have all in stock at work.
Reply #9February 21, 2011, 09:33:07 am
« Reply #9 on: February 21, 2011, 09:33:07 am »
Yes there should be different lengths.. fwiw, atleast four.. single v-belt (alt and wp), double v (alt/wp and ps/ac), serp belt, serp belt with v belt (wp, ps,).
If they took their old bolt out and got the measurements to you Lucas, would you be able to get them out to people
Reply #10February 21, 2011, 09:40:06 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #10 on: February 21, 2011, 09:40:06 am »
:D Not these little fingers lol......
These bolts are in there pretty good im gonna go out and buy a new set of vice grips and may even do the left handed drill bit trick too.... Wish i had an air chisel, this car is def forcing me to buy tools as i need them lol.... ;)
Reply #11February 21, 2011, 09:45:02 am
« Reply #11 on: February 21, 2011, 09:45:02 am »
VW themselves make an upgraded version of these bolts with increased hardness etc... TDI's use 'em but they'd retro-fit.  Most TDI timing belt kits come with the upgraded bolts.. since as you're finding out the old ones can be a pain.
I use anti-seize on 'em when I install 'em... some folks use locktite.
Reply #12February 21, 2011, 10:47:26 am
madmedix
  • 204
« Reply #12 on: February 21, 2011, 10:47:26 am »
Awhile ago I posted about these little beauties: Craftsman female extractors (or easy-outs). Have a search on my username. They're cheap, come in many sizes now and are also known to save mass quantities of skin, analgaesics & beer  :P
Andy
'90 TD Jetta
Reply #13February 21, 2011, 11:08:30 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #13 on: February 21, 2011, 11:08:30 am »
i went for the easy out set and i think i need a bigger size than the set i have now ill have to try sears
Reply #14February 21, 2011, 03:18:51 pm
« Reply #14 on: February 21, 2011, 03:18:51 pm »
yep any length we need
