Author Topic: WTB passenger rear view mirror small door manual adjust.  (Read 3789 times)
February 14, 2011, 11:02:11 am
« on: February 14, 2011, 11:02:11 am »
WTB passenger rear view mirror small door manual adjust.  Prothe has some but they are the 3 bolt for the big door. I cant find any for the one that bolts to the door instead of the window area...wouldn't mind having driver side as well, but I have to have the passenger.
Mine the adjusting cable broke, so if there is a way to fix that I would be open to suggestions too.
Reply #1February 14, 2011, 11:48:36 am
Re: WTB passenger rear view mirror small door manual adjust.
« Reply #1 on: February 14, 2011, 11:48:36 am »
manual adjust from outside?
or manual adjust with the lever inside?
Reply #2February 14, 2011, 12:52:46 pm
macka
  • 957
« Reply #2 on: February 14, 2011, 12:52:46 pm »
There is a small door at the local pick n pull I'll see if the mirrors work, and scoop them if they do so you have a spare. You need to to lube the swivels and cables so they don't sieze up.
Quote from: Vincent Walden
Reply #3February 14, 2011, 03:02:16 pm
« Reply #3 on: February 14, 2011, 03:02:16 pm »
manual adjust from the inside. The cable was broke on the passenger one since I had it. The driver I have shot some stuff into it and it seems to be fine.
Reply #4February 14, 2011, 07:59:38 pm
Familydiesel
  • 154
« Reply #4 on: February 14, 2011, 07:59:38 pm »
I have a good set of the 2 bolt with the cables, if you still need them, I will go up into the attic and double check.  I had someone who wanted them a little over a year ago, then backed out, but I need to double check.  LMK if you still need them.
1980 Diesel td pickup, Love that Diesel!
Reply #5February 15, 2011, 04:23:02 am
« Reply #5 on: February 15, 2011, 04:23:02 am »
I think I have found some. I will let you all know if I need them.
