Author Topic: Race Ware head bolt studs and MLS gasket  (Read 2632 times)
February 11, 2011, 07:14:38 am
RustyCaddy
  • 395
« on: February 11, 2011, 07:14:38 am »
Anyone know if the 50 ft/lb final torque specs for Race Ware studs is enough to crush and get a good seal with a MLS head gasket?
Folks seem to trust ARP to do the job but ARP seems to be able to take a lot more torque.
Reply #1February 11, 2011, 08:08:46 am
rodpaslow
  • 670
Re: Race Ware head bolt studs and MLS gasket
« Reply #1 on: February 11, 2011, 08:08:46 am »
Bently states up to I think 44 ft.lbs and then another 1/4 or 1/2 turn (not sure which) but I'm sure 50 is not enough.  My arp are torqued to 110 ft.lbs and no issues.  I only have about 10 k on it since, but I haven't had any problems with the mls at 110.
Reply #2February 11, 2011, 08:29:23 am
« Reply #2 on: February 11, 2011, 08:29:23 am »
50 is prolly enough for a fiber gasket, but i doubt a metal gasket is gonna seal at 50 ft lbs..
Reply #3February 11, 2011, 09:16:20 am
truckinwagen
  • 1895
« Reply #3 on: February 11, 2011, 09:16:20 am »
the torque discrepancy comes from the different thread pitches.
50 should be fine for a fiber gasket with low boost.
-Owen
83 Opel Kadett Diesel
Reply #4February 11, 2011, 11:54:46 am
« Reply #4 on: February 11, 2011, 11:54:46 am »
^ This
100 Ft/ lb on Raceware will most likely damage your head.
Reply #5February 11, 2011, 07:34:20 pm
RustyCaddy
  • 395
« Reply #5 on: February 11, 2011, 07:34:20 pm »
When ARP are torqued to 110 ft/lbs to crush a MLS thats about 30% over spec (i am assuming the ultra-toque stuff is being used...if not the comparisons get pretty shaky); so going to 65 ft/lbs with Race Ware would be about 30% over for them too.  i guess that 65 ft/lbs would be worth a try but Dr. Diesel in another thread went to 70 ft/lbs with Race Wares and thought he might have over torqued them and ended up pulling those studs...not much room for error.
i haven't compared the pitch between ARP and Race Ware side by side but they look really close.
Thanks guys for weighing in...that helps a lot.
And what the h*ll are head "bolt" studs in the thread topic anyways  :-[
