Author Topic: Tensioner stud question  (Read 4182 times)
February 05, 2011, 11:48:54 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« on: February 05, 2011, 11:48:54 pm »
After getting my head back from the machine shop I noticed they'd taken out the stud for the timing belt tensioner. I didn't think much about it at the time but now that I'm finally getting around to putting all this back together I can't remember which way the stud goes back in, or if it even matters. Anyone have a head laying around with the tensioner pulley off that they can look at real quick and refresh my memory?
Here's what I've got:
You can see from this picture I've got more thread to one side of the stud than the other.... I don't know for sure if that's how it's supposed to be or not. The only picture I can find of one is in the Haynes manual and it shows it being threaded equal lengths on both ends, with a much larger smooth portion in the middle. This could just be a home-made job that someone put in there at some point in the cars life, although it has worked just fine in the 14 or so years that I've owned the car.
So do I go with option 1:
Or option 2:
Any and all help appreciated
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #1February 06, 2011, 01:01:29 am
Runt
  • 83
Re: Tensioner stud question
« Reply #1 on: February 06, 2011, 01:01:29 am »
I do not know the correct (factory) orientation.
I do know (don't ask me how, just take my word for it ;-) that if possible a stud should ALWAYS be installed so that the shoulder of the stud meets the top of the threaded hole before the stud is able to bottom in the hole.  If a stud is allowed to bottom in it's hole, it can (or for me, definitely will) either 1)seize and then shear off, requiring me to waste much time extracting it, or 2)push through the thin, aluminum bottom of the threaded hole and penetrate the water jacket in the head, therefore causing me to say really bad words before I go looking for a replacement head.
I hope this helps.
One DD 92 Jetta, One 91 Collision write-off, and One 92 rust free shell, beautiful, stripped, waiting for diesel-ization.
Reply #2February 06, 2011, 01:11:35 pm
Thezorn
  • 381
« Reply #2 on: February 06, 2011, 01:11:35 pm »
Mine has the long portion of thread sticking out.
Compounded 93 AAZ
Reply #3February 06, 2011, 01:19:15 pm
« Reply #3 on: February 06, 2011, 01:19:15 pm »
2X.
Another clue is that sometimes when you buy 'em there's blue locktite on the short end.
Reply #4February 06, 2011, 09:31:58 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #4 on: February 06, 2011, 09:31:58 pm »
Thanks fellas. I kinda thought that's how it went but I wasn't sure so thought I'd ask. Interesting that with all the timing belt changes and other related stuff I've done over the years I never paid one bit of attention to how that stud was in there. I like to tell myself I would have noted the orientation had I taken it out myself... but who knows.
            1984 F-250
            1999 Ford Ranger
84 Rabbit
70 Bug
Reply #5February 06, 2011, 09:36:58 pm
« Reply #5 on: February 06, 2011, 09:36:58 pm »
Much better to reason things out... slow and careful like... especially when the timing belt is involved.   :)
Reply #6February 07, 2011, 09:47:48 am
GEE-BEE
  • 1604
« Reply #6 on: February 07, 2011, 09:47:48 am »
I will forward this to ex-wife # 1 , she thinks she knows something about stud's
I would go with 12.9 grade stud and locktite
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #7February 07, 2011, 08:52:23 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #7 on: February 07, 2011, 08:52:23 pm »
To which your reply should be "obviously not..... since you divorced me"
GB
Never heard of 12.9. 10.9 I have heard of though. One thing about this old car that makes me happy is a lot of the bolts are property class 10.9 (roughly equivelant to grade 8 in SAE usage), which means they'll probably all last as long as I do. I don't know for sure what that tensioner stud is, as there are no identifying marks on it, but it's still in good shape. I wonder though if a 10.9 would be overdoing it threading into aluminum? Probably no more than an 8.8 I guess, just thinking out loud.
« Last Edit: February 07, 2011, 09:00:11 pm by Rabbit79 »
            1984 F-250
            1999 Ford Ranger
84 Rabbit
70 Bug
Reply #8February 07, 2011, 09:06:13 pm
« Reply #8 on: February 07, 2011, 09:06:13 pm »
A stronger bolt would allow you to torque it harder in which case the head threads would give first. I'd go for a stronger bolt just so it could hold the side load.
Reply #9February 07, 2011, 09:50:03 pm
« Reply #9 on: February 07, 2011, 09:50:03 pm »
Torque spec on that 13mm nut is not that much mind you... I think you'll be fine with what you've got.  ;)
Reply #10February 07, 2011, 10:26:57 pm
« Reply #10 on: February 07, 2011, 10:26:57 pm »
Both of my diesels have a 15mm nut.
Reply #11February 08, 2011, 06:39:41 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #11 on: February 08, 2011, 06:39:41 pm »
Mine has the 15mm nut. 33ft/lbs is what the Bentley says for the nut, but I don't see anything for the stud. Granted I didn't look that hard either. I just went to 29 with blue loctite on the stud, as it felt like it was getting pretty tight and I really don't care to strip the threads out of the head (or crack it either). Hopefully it won't want to come out every time I loosen the tensioner.
            1984 F-250
            1999 Ford Ranger
84 Rabbit
70 Bug
Reply #12February 09, 2011, 12:09:31 pm
« Reply #12 on: February 09, 2011, 12:09:31 pm »
For the stud I think slightly more than finger tight is good.
Reply #13February 10, 2011, 11:02:12 am
belchfire
  • 140
« Reply #13 on: February 10, 2011, 11:02:12 am »
How tight are you guys cranking your timing belts? The stock bolt will do just fine for the loads involved. I'd put the short end in the head with a little blue loc-tite mainly so that there would be no possibility of the nut hitting the shoulder if it should project beyond the face of the pulley and then you would be turning the stud in the head and aluminum threads don't like that on a repeated basis.
The Owl of Minerva flies at dusk
'81 rabbit pick up  1.6 turbo diesel  SVO
