Author Topic: Greddy Intercooler Install  (Read 2169 times)
February 02, 2011, 05:53:47 pm
jpedro
  • 137
« on: February 02, 2011, 05:53:47 pm »
I have got a GREEDY intercooler that has 2.5" piping. just have to pull off the front bumper and mount it in there then run the piping. what size is the outlet OD on the Turbo and the inlet OD on the intake elbow? i need to order a couple silicone elbows and reducers from 2.5" just not sure on the sizes, and am to lazy to pull of the one i have there now. my turbo is a k24 and im in the process of using a garrett turbo off my old 1982 toyota landcruiser 3.4L diesel. it should work perfect for what i need.
1990 VW Jetta 1.6L TD 235000kms Custom cold air intake and Custom 3" straight pipe
1992 Ford F250 7.3L IDI custom everything you can possibly think of. ( my braging rights are live with this toy)
Reply #1February 02, 2011, 05:55:49 pm
truckinwagen
  • 1895
Re: Greddy Intercooler Install
« Reply #1 on: February 02, 2011, 05:55:49 pm »
the turbo outlet and intake inlet are close enough to 2" to use 2" couplers with t-bolt clamps.
they are actually something like 1-7/8 or something like that, but 2" works fine.
-Owen
83 Opel Kadett Diesel
Reply #2February 02, 2011, 06:09:28 pm
GEE-BEE
  • 1604
« Reply #2 on: February 02, 2011, 06:09:28 pm »
siliconeintakes.com will have our reducers, use a hump coupling if you need to have a slight angle
Any lined clamp s/s type is just as good as long as you bead the end's
cxracing.com is where I purchased my tubing from, just closer and better price..
Good Luck
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3February 19, 2011, 01:03:38 am
trav1856
  • 230
« Reply #3 on: February 19, 2011, 01:03:38 am »
Can we get some pics? :-D
1981 Rabbit Diesel
1981 Cabriolet
