Author Topic: Will this item fit in my 84 Rabbit that has A/C  (Read 5561 times)
January 07, 2006, 09:12:38 pm
RustyRabbit
  • 33
« on: January 07, 2006, 09:12:38 pm »
I need this water deflector, but it says it will only fit rabbits withOUT a/c, but mine does have A/C... Do you think it will fit anyway?
Here's the link: http://cgi.ebay.com/ebaymotors/VW-Rabbit-Scirocco-Caddy-Genuine-Vw-Water-Deflector-NEW_W0QQcmdZViewItemQQcategoryZ33685QQitemZ8027755783QQrdZ1QQsspagenameZWDVW
Reply #1January 08, 2006, 04:07:03 am
vwmike
  • 1158
« Reply #1 on: January 08, 2006, 04:07:03 am »
It will fit, but the A/C system has a different intake. There is a little door to let in outside air or recirculate the interior air over on the passenger side of the raintray. The non A/C cover is shorter and does not cover the A/C intake so you may end up with more water in the interior than you would if it wasn't there at all.
Reply #2January 08, 2006, 05:45:46 pm
RustyRabbit
  • 33
« Reply #2 on: January 08, 2006, 05:45:46 pm »
"so you may end up with more water in the interior than you would if it wasn't there at all."
Your saying that if I buy the water deflector that is made for non-A/C cars, I'll have more water in the interior?  How about if I never use the A/C?  It dosen't work anyway.
Thanks for the input!  I appreciate it.
Reply #3January 08, 2006, 05:49:22 pm
vwmike
  • 1158
« Reply #3 on: January 08, 2006, 05:49:22 pm »
The end of the plastic tray is right over where the inlet is for the AC/Defroster. The water may run right off the end and into the intake. The A/C normally recirculates so you'd actually be better off if you did use the A/C.
Reply #4January 09, 2006, 11:49:47 am
RustyRabbit
  • 33
« Reply #4 on: January 09, 2006, 11:49:47 am »
So unless I can find a water deflector that is especially made for cars with A/C, I'm better off not having one at all, right?
Thank you!
Reply #5January 09, 2006, 01:36:25 pm
vwmike
  • 1158
« Reply #5 on: January 09, 2006, 01:36:25 pm »
So, the non A/C one is still available and is part number 171819415F, however it says the A/C one is not.
If we look at the 85 Cabriolet we find it has a couple different water deflectors for A/C.  The earlier one is 155820415 and then later it went to 155820415A. If you punch in the part number, the earlier one has been superceeded to the 155820415A part number. I don't see why that wouldn't work as they are essentially the same car.
