Author Topic: Fuel filter relocation Caddy ( under the bed ) Rabbit Tuck  (Read 3000 times)
January 08, 2011, 01:52:05 pm
GEE-BEE
  • 1604
« on: January 08, 2011, 01:52:05 pm »
Iam moving my stock fuel filter to the location where the gas fuel pump was located
Welded the oem bracket in place, bolt the filter housing to the bracket, spray coated with undercoating.
I used a 7 mm rubber hose from the hardline ( under hood ) to a barb fitting to the clear hose to the pump
7mm rubber hose from the tank to the fuel filter and another short piece of 7mm rubber to the hardline
Cleaner engine compartment
perfect mod !
GB
« Last Edit: January 30, 2011, 02:34:53 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1January 30, 2011, 01:37:23 pm
Re: Fuel filter relocation Caddy ( under the bed ) Rabbit Tuck
« Reply #1 on: January 30, 2011, 01:37:23 pm »
