Author Topic: rad cooling fans, what difference?  (Read 1998 times)
January 07, 2011, 10:51:03 pm
gribur
  • 84
« on: January 07, 2011, 10:51:03 pm »
  I have an MK3 golf AAZ i need a used cooling fan assembly and Was wondering what the difference is between the rad cooling fans  on a car with a/c and one without a/c.  Can you use either one?  Is $50 a good price for one used?
Cheers guys
Reply #1January 08, 2011, 08:00:53 am
GEE-BEE
  • 1604
Re: rad cooling fans, what difference?
« Reply #1 on: January 08, 2011, 08:00:53 am »
non a/c - Auto trans fan is 450/250 watt two speed
1H0959455AD
man trans with or without air
a/c model is 250 watt single speed
1HM959455C
both models use a 305 mm dia fan
There is a belt that drives the aux 1H0119137
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2January 12, 2011, 02:11:59 am
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: January 12, 2011, 02:11:59 am »
I would find any fan & shroud no lower than, as GEE-BEE stated, 250 watts. watts (over size) are a good unit of measure for the kind of air flow the fan can produce. Unless it was designed by people who shouldn't be making fans and is remarkably inefficient for what ever reason.
Reply #3February 10, 2011, 07:58:38 pm
macka
  • 957
« Reply #3 on: February 10, 2011, 07:58:38 pm »
A little bit of a pain to do but a Ford Taurus fan and motor is the poor mans flex a lite.
Quote from: Vincent Walden
