Author Topic: Techtonic downpipe?  (Read 2817 times)
January 02, 2011, 03:28:24 pm
gribur
  • 84
Techtonic downpipe?
« on: January 02, 2011, 03:28:24 pm »
  I was just wondering how good these guys are and also is there anyone in Canada that can do the same work, saving me customs and shipping hassles.  I have an mk3 golf AAZ with KKK14.  I dont need a cat where I am located and would rather just run a catless 2.5" system straight through. What are the implecations of deleting the cat from this engine?  I am just assuming it will breathe better, but I am just not sure if its design intentions were strictly omissions or if it would play some other role as well.
thank you guys
Reply #1January 02, 2011, 03:36:05 pm
GEE-BEE
  • 1604
Re: Techtonic downpipe?
« Reply #1 on: January 02, 2011, 03:36:05 pm »
I have a complete S/S system, DP is a TT S/S 2.5 with a KO3 turbo
I wish I would of ceramic coated it at the outlet to the bottom , it's hard to stay clean
Well worth the money...
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2January 02, 2011, 04:34:03 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #2 on: January 02, 2011, 04:34:03 pm »
Gee Bee, did you have TT make that DP one off? I only see 2.25" DPs on their site for MKII and MKIII.
Reply #3January 02, 2011, 04:43:08 pm
gribur
  • 84
« Reply #3 on: January 02, 2011, 04:43:08 pm »
good question, also if it was a one off, did it cost extra?  how much more would the coating have been?
Reply #4January 02, 2011, 05:20:20 pm
GEE-BEE
  • 1604
« Reply #4 on: January 02, 2011, 05:20:20 pm »
I just called and spoke with Josh
300.00 for DP in 2.5
40.00 is what the tail pipe section cost for ceramic coating, I have since cut it off so it goes straight out the back with a s/s 30 degree downward tip
315.00 for the 2.5 alloy exhaust, I used this as a mockup for a local tube bender to make me a s/s , since it was not offered in s/s by TT
I did supply TT both manifold's and turbo's for fitment ( 1.9 AAZ )
KO3
T2/T3/K14/ K24
« Last Edit: January 02, 2011, 10:33:29 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #5January 02, 2011, 05:28:35 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #5 on: January 02, 2011, 05:28:35 pm »
Is this all in reference to your truck or another car?
Oh and thanks much for making the silicone hoses for vanagons! I have 2.90 sets now and cant wait to get the gasser turbo 2wd on the road ;)
Reply #6January 02, 2011, 09:04:12 pm
GEE-BEE
  • 1604
« Reply #6 on: January 02, 2011, 09:04:12 pm »
Your welcome
I just finished all the hoses for the 16 V engines ( breather also that was NLA ) and the Scirocco upper and lower radiator coolant hose another first for the industry..
GB
« Last Edit: January 02, 2011, 10:33:54 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #7January 03, 2011, 01:28:08 pm
  • 3468
    • McScrubbins Body Wash
« Reply #7 on: January 03, 2011, 01:28:08 pm »
If you have access to a welder and an angle grinder (or hack saw if you are skilled!) you can make your own downpipe for under $150 and the rest of the exhaust for even less (depending on how fancy you want to be)
My down pipe is just a 180 degree bend (cut appropriately) with an extra 90 degree bend to shoot it under the car and of course the appropriate flange for your turbo outlet. I bought the pipe and flange at the local autoparts store (Lordco). Not super fancy pants but it fit my budget.
This is for a Garett T3 on an AAZ in a mk2 jetta.
« Last Edit: January 03, 2011, 01:30:45 pm by Smokey Eddy »
