Author Topic: Motor has a loud tick  (Read 5887 times)
January 02, 2011, 08:34:38 am
Palmer
  • 17
    • rusteddesign
« on: January 02, 2011, 08:34:38 am »
I've had a rather loud tick in my car since august. Its a 1.9 idi In the past 3 months I've replaced the lifters, main bearings, rod bearings, the oil pump, and the vaccuum pump. The car has had ARP headsa bolts for quite some time, but when the main bearings were replaced I had ARP main bolts installed. And still, the tick is there and just a load as ever. What else could it be, and is there anything simple I could try to fix it.
Mods are ARP bolts as mentioned above, turbo from a 1.6, turned up fuel, and 2.5" turbo back exhaust.
Someone told me to put a 1/4 litre of tranny oil in my motor oil.. I think I'll wait for vwdiesel.net's input first.
rusteddesign.com
Reply #1January 02, 2011, 10:20:13 am
Re: Motor has a loud tick
« Reply #1 on: January 02, 2011, 10:20:13 am »
probably injector knock..
have you had your injectors serviced in the last 100 years?
Reply #2January 02, 2011, 11:04:46 am
Palmer
  • 17
    • rusteddesign
« Reply #2 on: January 02, 2011, 11:04:46 am »
I just got the car in June. I've never had them serviced. Is injector knock really loud? I thought they just had a quiet little tick. Having said that, I don't think i've ever heard one knock before.
rusteddesign.com
Reply #3January 02, 2011, 11:08:17 am
truckinwagen
  • 1895
« Reply #3 on: January 02, 2011, 11:08:17 am »
I have had injector knock that made me think the motor was going to throw a rod at idle.
it can be VERY loud, it can also be not so loud.
injector knock, depending on its severity, can sound like lifter noise or a bottom end coming apart.
-Owen
83 Opel Kadett Diesel
Reply #4January 02, 2011, 11:12:48 am
« Reply #4 on: January 02, 2011, 11:12:48 am »
The definitive "is the injector making that noise?" test is to loosen the top fuel junction at each injector, one at a time.  If the noise goes away when you've disabled a particular injector thar she blows!
Obviously you'll want to take the usual fuel safety precautions... eye and hand protection, fire extinguisher standing by, but at idle the fuel will just dribble out and it can be a very quick way to isolate the noise as an injector issue.
Reply #5January 02, 2011, 11:33:18 am
Palmer
  • 17
    • rusteddesign
« Reply #5 on: January 02, 2011, 11:33:18 am »
Oh sweet. It does sound just like my buddies car did right before he blew parts out of the back of his block. Hence the new main and rod bearings and main bolts, but those are never a bad idea.
I'll look into that next weekend.
rusteddesign.com
Reply #6January 02, 2011, 04:37:29 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #6 on: January 02, 2011, 04:37:29 pm »
With respect to what your buddy mentioned about tranny oil; he probably meant ATF. This method can work ok to free up sticky lifters. Since you have already replaced them, no need for that. also, putting ATF in the engine will require the engine to idle for about half an hour and then you have to change the oil.
I think you are being directed in the correct direction. Injectors can be pretty loud if they are out spec. Plus, it cant hurt to have them serviced. You will get more power and better economy with clean and properly popped injectors.
Reply #7January 03, 2011, 01:35:01 pm
  • 3468
    • McScrubbins Body Wash
« Reply #7 on: January 03, 2011, 01:35:01 pm »
Ditto on the injectors. Lifter knock is loud. Injector knock is irritating. You may want to check what the oil pressure is while the car is warm and idling.
Find another buddy with a loose oil pressure gauge and find the right fittings to put it in the location at the top of the cylinder head on the transmission side.
Should be a blue or grey sensor there.
Careful, as this hole can have some residual oil. Obviously do not try and swap the sensor for your test gauge with the engine running.
Reply #8January 03, 2011, 04:17:57 pm
Palmer
  • 17
    • rusteddesign
« Reply #8 on: January 03, 2011, 04:17:57 pm »
I have been meaning to pick up an oil pressure gauge for the car, as well as an EGT gauge. I get worried about my temps sometimes.
I need to get on this and see whats up..  Even homeless people are yelling at me to put oil in my car, haha.
rusteddesign.com
Reply #9January 03, 2011, 04:42:16 pm
Dakotakid
  • 1240
« Reply #9 on: January 03, 2011, 04:42:16 pm »
I am wondering if one or more of the lifter bores in the head are not distorted in some way. This could cause a new lifter to work improperly.
Is the knock high or low (location) on the engine?
Reply #10January 03, 2011, 04:46:47 pm
Palmer
  • 17
    • rusteddesign
« Reply #10 on: January 03, 2011, 04:46:47 pm »
Its hard to tell really. I know three of the best diesel mechanics around, and 1 said lifters, and the other two said it sounded lower and was the main bearings. Apparently it was neither. I need a stethoscope. After everything I've changed, it still sounds the exact same too.
rusteddesign.com
Reply #11January 03, 2011, 08:45:28 pm
Thezorn
  • 381
« Reply #11 on: January 03, 2011, 08:45:28 pm »
Id just get the injectors serviced then see whare that leaves you.
Compounded 93 AAZ
Reply #12January 04, 2011, 10:36:16 am
« Reply #12 on: January 04, 2011, 10:36:16 am »
x2 on the injectors..
Owner has never had them serviced, its time..
this is one of those maintenance items.. just like timing belts, and oil changes..
Reply #13January 04, 2011, 12:31:45 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #13 on: January 04, 2011, 12:31:45 pm »
Good Luck, but mine was a horrible  loud clack clack etc. If I ever pull the head for some engine destruction pornography... I expect to find a piston eaten by a failed gudgeon pin. But an oil leak and the girlfriend (oh, I wondered what that bright red light and loud buzzer were for.......25 miles DOH!) stopped me being interested. ::)
Reply #14January 04, 2011, 02:48:43 pm
Mark(The Miser)UK
  • 1557
« Reply #14 on: January 04, 2011, 02:48:43 pm »
Are you using ARP because the head had warped previously? If the head was skimmed, it is quite possible, coupled with the extra crushing effect of the studs on the gasket, some of the valves are kissing the piston crowns. That echoes through the engine... Mine did it for 20000 miles, and no harm done ;D
Mark-The-Miser-UK
