Author Topic: fs: 1.6 TD hydraulic tall block MF (illinois)  (Read 4578 times)
December 27, 2010, 10:12:25 am
D1ES3L
  • 62
« on: December 27, 2010, 10:12:25 am »
-1.6 Turbo Diesel block and hydraulic head which has been split. probably will need rebuild. this motor was imported from canada. MF is the block code. $400.
-also have several injection pumps available if you need cores as i do not know if they work. $100 for n/a $150 for turbo.
-also stripped an eco jetta. diesel fuel tank, wiring harness, fuel lines, body parts, ect.
no pics at the moment as I'm out of state.
location just outside of st. louis
81 scirocco--80 TD caddy--99.5 TDI golf
Reply #1December 27, 2010, 12:58:45 pm
Re: fs: 1.6 TD hydraulic tall block MF (illinois)
« Reply #1 on: December 27, 2010, 12:58:45 pm »
400 bucks is a bit steep for a long block that needs a rebuild..
Reply #2December 27, 2010, 03:29:53 pm
D1ES3L
  • 62
« Reply #2 on: December 27, 2010, 03:29:53 pm »
copy that.. I'm not sure if it needs a rebuild or not. maybe just rings, I really have no clue.
figured i needed to start somewhere. price is negotiable!
Reply #3December 27, 2010, 05:47:15 pm
Dakotakid
  • 1240
« Reply #3 on: December 27, 2010, 05:47:15 pm »
Do you have the intake and exhaust manifolds, along with oil lines and snorkle and air cleaner from the Eco engine?
Might very well have an interest.
Reply #4December 27, 2010, 07:21:45 pm
D1ES3L
  • 62
« Reply #4 on: December 27, 2010, 07:21:45 pm »
I'm running the eco motor in my caddy. everything is being used with the exception of the air cleaner box.  However, I might have a spare intake w/bov that is super clean and the turbo manifold. I'll have to check once i return home
Reply #5December 28, 2010, 05:49:05 am
dh13
  • 108
« Reply #5 on: December 28, 2010, 05:49:05 am »
Is it a CE1 or CE2 harness?
Also is the harness complete and in good shape? Will it come with the fuse panel and cluster?
1991 Jetta 1.6TD
1980 Caddy 1.6TD
Reply #6January 03, 2011, 04:40:07 pm
dh13
  • 108
« Reply #6 on: January 03, 2011, 04:40:07 pm »
Still looking for info on that harness. Thanks
1991 Jetta 1.6TD
1980 Caddy 1.6TD
Reply #7January 05, 2011, 02:23:09 pm
  • 2931
« Reply #7 on: January 05, 2011, 02:23:09 pm »
I'm looking for a waterpump pully.
Got one that was relly bent up, but looks like the right size.
Part # is 068 121 037L
nearly 4 1/2" diameter
lip sits 1/4" off the surface when center is on table.
