VWDiesel Blog
Facebook Group
VWD on Twitter
TDI Engine -General Info
1Z/AHU Intake Manifold Cleanse - few questions
Pages:
Topic: 1Z/AHU Intake Manifold Cleanse - few questions (Read 12683 times)
Reply #15
December 21, 2010, 02:01:43 am
maxfax
Re: 1Z/AHU Intake Manifold Cleanse - few questions
Reply #15 on:
December 21, 2010, 02:01:43 am »
Nothing wrong with using a solvent.. Get the valve closed.. Good ole carb cleaner in an aerosol can should be the ticket to get things loosening.. Since you have the luxury of having the engine out on a stand, tip the engine in such that anything you spray in the port will run out.. Then break out the wire wheel, or weapon of choice.. When you're done break out the compressed air and blow gun.. Repeat as necessary... Maybe a final shot with the carb cleaner to rinse it out, blow it again, bada bing bada boom...
Last Edit: December 21, 2010, 02:04:11 am by maxfax
Reply #16
December 21, 2010, 06:44:32 am
catlin_cava
Reply #16 on:
December 21, 2010, 06:44:32 am »
Bottle cleaner brush on the end of a 18V drill made my intake SHINE inside! That's after I had all the big stuff removed
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #17
December 22, 2010, 08:16:10 pm
Reply #17 on:
December 22, 2010, 08:16:10 pm »
Ok so here is what I did. 24hr soak with some heavy duty cleaning agent, drain, 24hr soak with same agent, drain, lotta gooo came out. One more 24hr soak and screwdriver proding. I am off to the carwash to use a industrial power washer as we speak. And after that I'll prob do another soak and go in to it with a small wire wheel on a movaeble extension. I think it will be awwesome
Reply #18
December 29, 2010, 09:35:34 pm
Reply #18 on:
December 29, 2010, 09:35:34 pm »
Never had to do anything after the heated pressure wash. It came out shining! I will get some pictures.
Also I took Maxfax's advice on turning the cam to block off the ports on 2-3-4 cyl and started going at it in there. Got most of the big stuff out, and as i went to grab my compressor it seems the plastic line that came with it got kinked and has a leak now
however I do not think compressed air will be enough to get this stuff outta the port now.. its pretty gummy stuff.
any other ideas?
Reply #19
December 30, 2010, 12:50:33 am
maxfax
Reply #19 on:
December 30, 2010, 12:50:33 am »
Flush it with carb cleaner.. Or, have you ever seen seen one of the air sprayers? You use your compressed air and it has a tube to siphon your solvent of choice and spray it too.. They work nice for degreasing engines and parts.. Gasoline works great with these..
Here's an example of one..
http://shopping.yahoo.com/22593643-amflo-amf220td-blow-gun-siphon-sprayer-with-8ft-plast-tubing-superceded-220td/;_ylt=AjKM6OV_qfuyW3zWhcz6mnwbFt0A
Reply #20
December 30, 2010, 01:08:09 am
Powered by Spearco
Reply #20 on:
December 30, 2010, 01:08:09 am »
I have one today that need cleaning. '01 New Beattle ALH.
I've done these many times before. I dig out the hard stuff as much as possable and then soak over night in solvent tank. Then finnish it out with carb/choke cleaner.
Heres some of todays before pics.
I'll keep this updated tomarrow.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #21
December 30, 2010, 10:36:24 am
Reply #21 on:
December 30, 2010, 10:36:24 am »
damn that intake is super constricted eh!
I mean for the ports in my head, I have scraped and there is a lot sitting right on the valve head.. I am concerned i will not be able to get it all out. and a solvent i do not wish to put in the head for fear of it seeping past the valve seats.. lol
Reply #22
December 30, 2010, 12:02:18 pm
Reply #22 on:
December 30, 2010, 12:02:18 pm »
take the cam out and scrape the crap on/around the top of the valve, then blow it out of the port with compressed air.
or just turn the engine over until the valve is closed on the port your working on..
Reply #23
December 30, 2010, 12:04:32 pm
Reply #23 on:
December 30, 2010, 12:04:32 pm »
does pose a problem when your air compressor wont put out enough pressure to blow that crap out.
Reply #24
December 30, 2010, 01:26:44 pm
Reply #24 on:
December 30, 2010, 01:26:44 pm »
Yes, the problem is not the stuff getting in to the cylinder.. Its the stuff not getting out of the port. I really don't want to pull the cam.. I guess ill just have to get something to snake in there and grab it all out..
Fun experience.
Reply #25
December 30, 2010, 01:47:49 pm
Reply #25 on:
December 30, 2010, 01:47:49 pm »
squirt some carb cleaner in there, and use a bottle brush and it should loosen all that crap right up. a decent, small sized bottle brush should get right down to the back side of the valve head..
even if you do have to take the cam out, dont worry, just remember you own a VW. be glad it is not a v-tec equipped honda..
its very simple (as im sure you already know) to pull a vw cam..
Reply #26
December 31, 2010, 12:56:12 am
Powered by Spearco
Reply #26 on:
December 31, 2010, 12:56:12 am »
Heres what I got after just scraping and a over night soak in the solvent tank (basicly diesel).
Plus about half a can of Berrymens carb/choke cleaner.
The head ports were nasty and had hard caked on crud. Pulling the cam is a lot further than I want'ed to go, and rolling the engine over and duct taping the open ports is much faster.
'13 Golf R:. Tuned
'98 Puch G320
Reply #27
December 31, 2010, 01:08:37 am
Powered by Spearco
Reply #27 on:
December 31, 2010, 01:08:37 am »
I used a long steel pic and some small headed screw drivers to get at it. Then blowing it out with compressed air.
When all was done with the rest of the work I did. One the first start, it blew out alot of black soot. I had checked the VNT before to make sure it move freely, but its been driven like a "Grandma" for all 130K miles. I'm supprised.
It now runs with power and doesn't smoke anymore.
'13 Golf R:. Tuned
'98 Puch G320
Reply #28
January 01, 2011, 07:31:33 pm
vanagonturbo
Reply #28 on:
January 01, 2011, 07:31:33 pm »
I use solvent, a parts washer, a drill, and half of an old ebrake cable. Take the end of the cable and slightly unwind it, put it on the drill and go to town!
Reply #29
January 01, 2011, 07:58:03 pm
Powered by Spearco
Reply #29 on:
January 01, 2011, 07:58:03 pm »
Thats a great idea! I'll try that next time.
'13 Golf R:. Tuned
'98 Puch G320
Pages:
