Author Topic: 11mm 1.6 TURBO block?!?!  (Read 5354 times)
December 12, 2010, 01:57:33 pm
« on: December 12, 2010, 01:57:33 pm »
someone is telling me they have a 11mm turbo block? i thought all turbo engines had 12mm head bolts..
Reply #1December 12, 2010, 02:06:28 pm
Re: 11mm 1.6 TURBO block?!?!
« Reply #1 on: December 12, 2010, 02:06:28 pm »
they did
Reply #2December 12, 2010, 02:39:50 pm
« Reply #2 on: December 12, 2010, 02:39:50 pm »
they did make an 11mm TD?
or they did all come with 12mm?
Reply #3December 12, 2010, 02:58:39 pm
« Reply #3 on: December 12, 2010, 02:58:39 pm »
The turbo motor was an addition in 84 wasn't it?? Therefor making the engines in 83.. 12mm mech blocks.. When was the first year iof factory TD?
Reply #4December 12, 2010, 03:02:36 pm
« Reply #4 on: December 12, 2010, 03:02:36 pm »
Yup 83 being first year for factory TD would make it a 12mm mechanical engine.
"North America/Japan:
I4 petrol engines
1.6L 76 hp (57 kW) (MY 1980)
1.7L 74 hp (55 kW) (MY 1981-1984)
I4 diesel engines
1.6L 52 hp (39 kW) (1982-1984)
1.6L 68 hp (51 kW) (1983-1984)"
Sources from Wiki-pedia ;)
Reply #5December 12, 2010, 03:07:48 pm
« Reply #5 on: December 12, 2010, 03:07:48 pm »
guy said he has a 82 rabbit with a turbo motor, and said it has piston cooling jets, and 11mm bolts. he said he is positive it has 11mm bolts..
i dont know of VW ever producing a 11mm turbo engine.
my audi 5k TD prolly has 11mm bolts, but its a 5 cyl.. and totally different.
Reply #6December 12, 2010, 04:24:18 pm
maxfax
  • 2126
« Reply #6 on: December 12, 2010, 04:24:18 pm »
 I wonder what the code is on the block..  Maybe someone machined and drilled for the cooling jets..   Although that would even be a pain on an 11mm block.. They didn't have the flat spots machined over the oil passage where the jets go..
Reply #7December 12, 2010, 06:00:06 pm
« Reply #7 on: December 12, 2010, 06:00:06 pm »
Hmm, well seeing as how Vw never offered the TD in the USA for the 1982 model year.. and even if they did the 82 model year (depending on a late model of that year) would have 12mm stuff.
I can only find TD's being offered post-83. Therefore if it is in an 82.. its gotta be a custom job, or a later engine.. Even Europe didn't have the td in 82.
Reply #8December 12, 2010, 06:02:45 pm
« Reply #8 on: December 12, 2010, 06:02:45 pm »
a little more digging prevails that a 1982 TD existed! However it was sold in a Volkswagen Santana;
However this car was only sold in Brazil, Nicaragua, China and some European countries. Not North America...
I cant find anything on an 11mm TD tho..
Reply #9December 12, 2010, 07:12:24 pm
« Reply #9 on: December 12, 2010, 07:12:24 pm »
i have never heard of an 11mm td, and even if there was a 1982 td it still would have been a 12mm engine since 1981 was when they switched to 12mm, santana is the same thing as a quantum
Reply #10December 12, 2010, 11:42:49 pm
maxfax
  • 2126
« Reply #10 on: December 12, 2010, 11:42:49 pm »
There were some 11mm engines in early '82..  I've only seen them in Westmoreland built Caddys with a build date before 12/81..
Reply #11December 13, 2010, 01:10:53 am
VW Smokr
  • 114
« Reply #11 on: December 13, 2010, 01:10:53 am »
As stated... if really an 11mm bolt block, it's NOT a factory turbo block. In building status in my shop is a NOS factory 11mm "fitted-block", but with with piston cooling squirters added. It's being built as an intercooled 1600TD, but definitely not OG, and much modded (for survival). Nice to trust people, but some folks don't know, except what they're told, while others make up 'convenient' stories to cover unknowns, odd builds, miscellaneous mix 'n match accumulations, and total hack jobs that they want to sell. Not accusing, just saying... !
BTW the diesel Rabbits assembled in Westmoreland County, PA, unlike the gassers, did not source their engines in the U.S. Those engines were shipped in fully-assembled from Germany. Later VW did trust the Mexicans with diesel engine assembly, but never the Yanks. If any early Westmoreland '82 Rabbits actually were fitted with 11mm head bolts(?), those few engines were from leftover '81 stocks, somehow still sitting there, not new TDs. '82-'88 Quantums (Passat Mk 2) were built in Germany, as were the '74-'81 Dashers (Passat Mk1) before them.
J.R.
SoCal
Reply #12December 13, 2010, 01:40:21 am
maxfax
  • 2126
« Reply #12 on: December 13, 2010, 01:40:21 am »
That's sort of what I suspected.. Double checking, the build date on both Caddy's is 7/81 not 11 as I was thinking.. That'd be about as early as one could get for an '82 model..
I'm kinda curious now, any particular reason for adapting this block other than it being a new one?
« Last Edit: December 13, 2010, 01:43:40 am by maxfax »
Reply #13December 13, 2010, 08:38:07 am
« Reply #13 on: December 13, 2010, 08:38:07 am »
that looks like an audi 4000 or VW quantum damn near..
and like i said..
my Audi 5000.. its a 82 or early 83, cant remember for sure..
pretty sure it got 11mm bolts unless someone knows something i dont..
and pieces i pulled off a MF engine, had date stamps of 4/82 on them..
sure there is the possibility of 11mm TD engines, but not 4 bangers in 82.
block is supposed to be a CY code.. and the owner is POSITIVE the block has 11mm holes.
Reply #14December 13, 2010, 08:43:27 am
« Reply #14 on: December 13, 2010, 08:43:27 am »
