General Information
General
Cluster Going Bananas
Topic: Cluster Going Bananas (Read 5166 times)
December 04, 2010, 04:11:17 pm
91jettaidi
December 04, 2010, 04:11:17 pm »
Hey guys so I finally finish my 1.6TD swap into my 90' Flair 2 now the cluster from the parts car was damaged so I got a new one from a friend. When the old cluster from the parts car was running it never showed any thing on the dash now with the new one I got it always shows low oil presser all the time (witch there isn't) and its over heating. When I was driving the car around for the 1st month those 2 lights were always flashing and the temp shows full heat all the way to the end of the bar even if it was cold. Now the car has a new rad, water-pump with fresh coolant so its fine. Then the other day I was just waiting around for my friend and letting the car idle for about 2-3 min. The temp gauge then just suddenly went to below the solid white point on the far left of the gauge and stayed there. I think its probably the sensors but it was fine on the other cluster when I was driving the car around so I really don't know. Also the speedo some times get the nervous shake I like to call it from 40k-60k and 75k-90k no idea why. Thanks allot hope to hear some good reasoning for this I've been driving MK2's all my life and not one of then and ***ty as some of them looked never had any warning lights on the dash thanks.
December 04, 2010, 05:42:27 pm
Re: Cluster Going Bananas
December 04, 2010, 05:42:27 pm »
could be that the membrane has bad connections on it, they are hard to trace, or the voltage regulator could be bad, try switching it with the one from your old cluster
December 05, 2010, 07:51:14 am
December 05, 2010, 07:51:14 am »
let me know if that works
December 05, 2010, 09:51:05 am
91jettaidi
December 05, 2010, 09:51:05 am »
ahhh well only problem is that the car is now stored for the winter but I threw out the old dash. I might just get a new one and pop it in
December 05, 2010, 05:01:42 pm
December 05, 2010, 05:01:42 pm »
u can probably buy one pretty cheap check mouser.com for w/e numbers are on your voltage regulator, its nothing special
General Information
General
