Author Topic: head gasket leak??? with arp studs  (Read 8485 times)
Reply #30February 13, 2011, 08:02:54 am
pyro7890
  • 47
Re: head gasket leak??? with arp studs
« Reply #30 on: February 13, 2011, 08:02:54 am »
well when i put my head gasket on with the head off i noticed that the gasket really has a lot of room to move around enough so that the gasket could interfere with the piston projection and also not have an efficient seal for the coolant holes
Reply #31February 13, 2011, 08:09:11 am
« Reply #31 on: February 13, 2011, 08:09:11 am »
Maybe try unscrewing 2 of the studs so that it catches the gasket? I have 0 problems with studs, but made old bolts in to a locator pin before I had them. I just unthreaded when I was done and put the bolts in. I would do it so 1/2 a thread or so is above the block surface on the 2. Just enough to keep the gasket in place until you can tighten the other 8 enough to hold it so you can tighten the original 2. You don't want it to hold the head off the block...you should be able to do this.
