Author Topic: What years 02a trans' on?  (Read 10717 times)
November 30, 2010, 12:39:25 pm
rallydiesel
  • 1880
« on: November 30, 2010, 12:39:25 pm »
I'm looking to eventually switch to a 02a trans and am willing to buy a complete car to get it. What years did they start using them? I always thought the AAZ's had them but I think that's not right. Anybody know? Specifically when they used them on diesel cars since I will want those ratios anyways and then I can make use of the engine as well. Thanks!
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1November 30, 2010, 01:06:32 pm
Wayland
  • 364
Re: What years 02a trans' on?
« Reply #1 on: November 30, 2010, 01:06:32 pm »
I'm no expert, but the MkIII diesels seem to still have the 020, while the Passats of the same era (93 up) use the 02A.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #2November 30, 2010, 07:51:06 pm
« Reply #2 on: November 30, 2010, 07:51:06 pm »
Early TDI's got them for sure. Possibly in passats as early as 93 (?? confirmed). Mk3 golfs will not have the 02A's as they never received the TDI until the '99.5 model year. mk3 passats (96-xx) with tdi's, 97+ mk3 jetta's.
02A's are very strong transmissions. That hydro clutch is the bee's knees
« Last Edit: November 30, 2010, 08:02:49 pm by 8v-of-fury »
Reply #3November 30, 2010, 07:54:08 pm
MJF
  • 581
« Reply #3 on: November 30, 2010, 07:54:08 pm »
All 88-96 Passats have 02A.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #4November 30, 2010, 09:55:39 pm
rallydiesel
  • 1880
« Reply #4 on: November 30, 2010, 09:55:39 pm »
So a Passat with an AAZ will have an 02a while any other AAZ will have a 020?
Reply #5November 30, 2010, 10:38:39 pm
Powered by Spearco
  • 1203
« Reply #5 on: November 30, 2010, 10:38:39 pm »
Do you plan on using the hydro setup or the mech. setup?
I'm running the mech. setup on my truck using the cable from a Honda CRX. Its works great.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #6December 01, 2010, 11:20:15 am
rallydiesel
  • 1880
« Reply #6 on: December 01, 2010, 11:20:15 am »
So what did you do about the clutch slave cylinder?
Reply #7December 01, 2010, 11:41:14 am
BigVWman
  • 332
« Reply #7 on: December 01, 2010, 11:41:14 am »
Just be careful of the vr6 passats from that era also had 02a's but the bolt pattern is just a tad off for the 4 cyl block. Angled slightly on the top two bolts IIRC.
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #8December 01, 2010, 07:51:02 pm
« Reply #8 on: December 01, 2010, 07:51:02 pm »
yes only 4cyl 02A's will work for other 4 cyl
Reply #9December 01, 2010, 09:06:36 pm
« Reply #9 on: December 01, 2010, 09:06:36 pm »
Correct.
Reply #10December 01, 2010, 10:02:04 pm
Powered by Spearco
  • 1203
« Reply #10 on: December 01, 2010, 10:02:04 pm »
Even a 020 will bolt to a new 2.5,  5 cylinder.
I used the VW early Eurovan mechanicle slave conversion unit. Reinforcing the peddal assembly will be needed.
'13 Golf R:. Tuned
'98 Puch G320
Reply #11December 02, 2010, 04:46:51 pm
« Reply #11 on: December 02, 2010, 04:46:51 pm »
There really isn't too much work involved in setting up the hydro clutch... And its so much nicer lol
