Author Topic: Head studs question  (Read 6402 times)
Reply #15November 29, 2010, 09:46:59 am
Re: Head studs question
« Reply #15 on: November 29, 2010, 09:46:59 am »
On my old mk2 I could hit 1200 no problem, but....
I had tons of fuel. I build pumps as well that one would about droun the engine if I wasn't careful. Used injector tips off a CASE backhoe.
Was also running a huge front mount and a hybrid kkk24/26, full 3" turbo back.
Anyway, I ran the ARP's in the first post with a MLS gasket and hit 40psi several times, oftin ran it at 30psi sustained. I detuned that engine quite a bit when I sold it so it would be easier to drive. It's still on the road blowing smoke today...
He actually has it for sale I think.
Reply #16November 29, 2010, 09:57:57 am
« Reply #16 on: November 29, 2010, 09:57:57 am »
isnt the 24/26 an agreed upon performance restriction? the hot side being too restrictive for the massive K26 cold scroll?
Reply #17November 29, 2010, 10:01:41 am
« Reply #17 on: November 29, 2010, 10:01:41 am »
Not that I'm aware of.
Have the 24 hot side machined as I did and your set.
Drive pressure was about 1.1:1 and less most of the time. So 25psi on the cold side and 30psi on the hot side.
The problem is (at least at my elevation) it takes to damn long to spool for normal driving. I swapped on a 24 when I sold it again so it was easier to drive.
Reply #18November 29, 2010, 07:13:53 pm
RadoTD
  • 513
    Stage WTF
« Reply #18 on: November 29, 2010, 07:13:53 pm »
Did you ever run that engine on a dyno or drag strip? How quick would it be, say compared to a good running stock VR?  ;)
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #19November 29, 2010, 09:04:54 pm
« Reply #19 on: November 29, 2010, 09:04:54 pm »
Even a mildly tuned vr would be seen in the rear view mirror, never tracked it but I did run out up against a couple 318's and several hondas. the only car that ever really challenged me was a really built WRX. We ran out of road and bothh of us have the other thumbs up...
Reply #20November 29, 2010, 09:29:13 pm
« Reply #20 on: November 29, 2010, 09:29:13 pm »
was it a coupe in york pa?
Reply #21November 29, 2010, 09:36:32 pm
RadoTD
  • 513
    Stage WTF
« Reply #21 on: November 29, 2010, 09:36:32 pm »
That's sweet :) Can't wait to get mine running! haha
Reply #22November 30, 2010, 07:03:39 am
« Reply #22 on: November 30, 2010, 07:03:39 am »
Nope. Sedan in Utah.
« Last Edit: November 30, 2010, 09:52:51 am by Vincent Waldon »
