Author Topic: Finding TDC on a 5000TD  (Read 3289 times)
November 19, 2010, 12:14:44 am
Toby
  • 728
« on: November 19, 2010, 12:14:44 am »
Does anyone have a good way to find TDC on a 5 grand TD? The 3 marks don't match. The one on the flywheel end does not have a pointer. I suppose I could try to fish a section of wire through the PC chamber and split the difference between where it locks up CW and then CCW but I was hoping to not have to touch the injectors until later.
I had to remove the vacuum pump pulley to straighten it, so lost the IP timing. I set it at .110 by the mark from the .093 it had (by the same incorrect mark) when I got it. Seems to run better, but I think I lost some mileage, so I want to check and reset it when I adjust the valves in the AM.
Reply #1November 23, 2010, 09:48:17 pm
AudiVWguy
Re: Finding TDC on a 5000TD
« Reply #1 on: November 23, 2010, 09:48:17 pm »
Instead of using a wire, use your pump timing gauge to accurately find TDC. I think its in the FAQ section.
Cheers,
-JB
Reply #2November 23, 2010, 10:23:13 pm
Toby
  • 728
« Reply #2 on: November 23, 2010, 10:23:13 pm »
How pray tell would I do that? I do not think there is a straight shot from injector socket to the outlet of PCC.
