Author Topic: 1.5/1.6 Hybrid  (Read 21272 times)
Reply #45November 17, 2010, 05:59:38 pm
Mark(The Miser)UK
  • 1557
Re: 1.5/1.6 Hybrid
« Reply #45 on: November 17, 2010, 05:59:38 pm »
The data that is floating around, is in the pump pressure sticky on the other site. I discovered that that particular pump had a slightly faster advance curve, or at least the internal pump pressure rises more steeply than the later pumps but that could easily be countered by a slower advance mechanism... :-\
Mark-The-Miser-UK
Reply #46November 19, 2010, 11:37:18 am
Zukiman87
  • 65
Re: 1.5/1.6 Hybrid
« Reply #46 on: November 19, 2010, 11:37:18 am »
Other than running a vnt turbo what is the next best option?
Reply #47November 19, 2010, 12:34:03 pm
Re: 1.5/1.6 Hybrid
« Reply #47 on: November 19, 2010, 12:34:03 pm »
compounds probably?
Reply #48February 09, 2012, 02:29:31 pm
Zukiman87
  • 65
Re: 1.5/1.6 Hybrid
« Reply #48 on: February 09, 2012, 02:29:31 pm »
So it's been awhile since I started on my hybrid build. Took me awhile to ind the perfect block to put the 1.5 pistons into. Got it cleaned up and painted I'll post a pic soon. Now I'm going to start putting the pistons and bottom end into it. I'd like to put the Arp rod bolts in but from what I've read are a pain in the butt to do. Anyone done them in the 1.5 rods and does anyone have a part number for them? Or are they the same part number as the 1.6 rod bolts?
Reply #49February 09, 2012, 02:49:34 pm
Re: 1.5/1.6 Hybrid
« Reply #49 on: February 09, 2012, 02:49:34 pm »
Do the rod bolts u can just take them to a machine shop they'll press them in for a few bucks I got new arp rod bolts and bushings in mine had them polished and balanced  and big ends resized it cost me 100 plus 120 for the bolts
« Last Edit: February 09, 2012, 02:55:46 pm by Trev0rbr »
Reply #50February 09, 2012, 07:38:33 pm
maxfax
  • 2126
Re: 1.5/1.6 Hybrid
« Reply #50 on: February 09, 2012, 07:38:33 pm »
^^^^ What he said..  They aren't so bad to actually press in the rods, but the rods themselves need to be checked and possibly (most likely) resized...   ARP # 104-6002
Reply #51February 09, 2012, 08:49:33 pm
Zukiman87
  • 65
Re: 1.5/1.6 Hybrid
« Reply #51 on: February 09, 2012, 08:49:33 pm »
So I should probably measure each rod before I put the bolts in and if neccesary machine them
Back down to that size hey
Reply #52February 09, 2012, 11:55:56 pm
maxfax
  • 2126
Re: 1.5/1.6 Hybrid
« Reply #52 on: February 09, 2012, 11:55:56 pm »
What happens most time when you install the studs is that they sort of "stretch out the hole" since they press in there rather snugly.. This will leave you with a bump more or less right in the center of the journal on each side.. Of course this bump will push out on that one small area of the bearing, and I think you can probably imagine what bad will follow..   :o
Reply #53February 11, 2012, 11:29:42 am
Zukiman87
  • 65
Re: 1.5/1.6 Hybrid
« Reply #53 on: February 11, 2012, 11:29:42 am »
What brand of rings to you guys reccomend to run? Any to stay away from? Other than the 20$ sets lol
Reply #54February 11, 2012, 03:52:15 pm
maxfax
  • 2126
Re: 1.5/1.6 Hybrid
« Reply #54 on: February 11, 2012, 03:52:15 pm »
Grant or Goetze are pretty safe bets..  The $20 specials and Top Line rings I would avoid..
Reply #55February 12, 2012, 07:24:41 pm
Re: 1.5/1.6 Hybrid
« Reply #55 on: February 12, 2012, 07:24:41 pm »
Goetze are the only ones i will run, maybe total seal if they make them now.
Reply #56March 23, 2012, 10:13:34 am
Zukiman87
  • 65
Re: 1.5/1.6 Hybrid
« Reply #56 on: March 23, 2012, 10:13:34 am »
So I have everything to swap the bottom end of the 1.5 into the 1.6. Grant rings kolpenschmidt bearings and arp rod bolts. Only thing I need is a pooched 1.6 piston so I can match up the notch with my 1.5 pistons. Any one have a donor they want to part with? Only need one piston! Don't want to go buy a brand new one and none of the wreckers have anything. Any help would be awesome!
Reply #57March 23, 2012, 10:52:13 am
Re: 1.5/1.6 Hybrid
« Reply #57 on: March 23, 2012, 10:52:13 am »
prothe sells pistons CHEAP.. may be able to buy just one for around 50 bucks..
Reply #58March 23, 2012, 01:34:52 pm
Re: 1.5/1.6 Hybrid
« Reply #58 on: March 23, 2012, 01:34:52 pm »
I have some 1.6 TD pistons. You pay shipping both ways and I would let you borrow one to use.
Reply #59March 23, 2012, 01:50:50 pm
Re: 1.5/1.6 Hybrid
« Reply #59 on: March 23, 2012, 01:50:50 pm »
what about the BEAT UP piston out of your engine that lost a pre-cup?
