Author Topic: SWAP mk3 golf AAZ into MK3 golf gasser  (Read 1938 times)
November 05, 2010, 09:40:53 pm
gribur
  • 84
« on: November 05, 2010, 09:40:53 pm »
I have already done a lot of research.  Both are manual tranny. I have mk3 AAZ (dead body) have MK3 gasser no engine good body. I have diesel engine out and gasser awaiting transplant.  I just want you guys to list off everything i need to swap over from the diesel into/onto the gasser.  I want to make sure I have all of my i's dotted and t's crossed.  Please list every last part you can think of that needs to be swapped off of the diesel and put onto the gasser
thanks guys, my sanity and winter driver depend on you!.
   So far I have the AAZ pulled, wiring harness not out yet.  I have the front sub frame out, everything minus the steering rack, as they look the same on both cars , not too sure if rear sub frames differ between a diesel and a gas, have not had a good look yet.  Have the weekend to basically get everthing else out/of  of the diesel to put into the gasser.  After that the remainder of the diesel shell and interior need to be gone for more room.
« Last Edit: November 05, 2010, 10:03:43 pm by gribur »
Reply #1November 05, 2010, 09:56:42 pm
gribur
  • 84
Re: SWAP mk3 golf AAZ into MK3 golf gasser
« Reply #1 on: November 05, 2010, 09:56:42 pm »
was just looking at the shifter and all related parts and it looks as though i will need to pull all of the shift related parts from the diesel and put them onto the gasser, totally different from what i can see.
Reply #2November 06, 2010, 08:00:44 am
Patrick
  • 1034
« Reply #2 on: November 06, 2010, 08:00:44 am »
Does that mena you have an 02A trans in one and an 020 trans in the other?
Fixmyvw.com
