Author Topic: how much boost with stock manifold? (CAD pics inside)  (Read 2730 times)
November 04, 2010, 11:33:56 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« on: November 04, 2010, 11:33:56 pm »
Hi All,
I am currently running my aaz up to 25psi with the stock manifold (using merc t3). If anyone saw, it made 110hp at the wheels on the dyno the other day. Anyway, I'm in the process of designing/making a new manifold to squeeze in front of the turbo with some runners and duel plenum (see pics) but just thought - is anyone else running this much boost (and since its a merc t3, its actually quite a lot of air flow) through the stock manifold?
I still have stock headbolts.... just worries me a little the thought of all the preferential feeding to cyls 2 and 3
pics of my new manifold design for your interest:
I plan on using the flange->90 deg turn from a 1z manifold I have cut up for the inlets, and fabbing up the rest. Desinging it in cad gives me the convenience of getting the flat panels laser cut from sheet to the right shape so all i have to do is tack and weld them together.
« Last Edit: November 04, 2010, 11:38:13 pm by gldgti »
'91 Golf Cabrio 1.9TD
Reply #1November 05, 2010, 06:05:00 am
Re: how much boost with stock manifold? (CAD pics inside)
« Reply #1 on: November 05, 2010, 06:05:00 am »
Just an idea. My mani that I can't use is shaped similar, see my build thread for pics if you want. You will have to take the intake off to get to the valves if it is like that. If you are designing then building it is something to consider.
Reply #2November 05, 2010, 01:46:09 pm
gldgti
  • 488
« Reply #2 on: November 05, 2010, 01:46:09 pm »
Libby, see my post in the other thread re my design.
In australia, mk2's are rare and mk2 diesels non-existent altogether, so not sure what this manifold your talking about looks like, but i'm interested to see a pic...
theman53 - i thought about valve cover access, and i have dimensioned it appropriately so I can still remove the valve cover. I saw the pic of your manifold in the other thread, it looks a bit 'lower' on the underside. good point to consider though. I think I will measure up the head and put that in the 3d model as well, so that i can be 100% sure of the design.
Reply #3November 05, 2010, 05:47:34 pm
bugnut
  • 89
« Reply #3 on: November 05, 2010, 05:47:34 pm »
Here is my try at the dual plenum design.  To say the least it bent my rods.  That was at 30 psi. I think the water injection didn't help any.  All the rods were bent just a little bit more the the other starting at number 1 as the most and working it way down to #4 being not bent at all.  My slit from on chamber to the other is 110% the intake opening.  That is a number I found somewhere and went with it.  I might try and make another one with 85% opening and open up the second plenum to the same volume of the engine or a little bigger.  Maybe 2 liters.
1980 Rabbit  1.9/1.6 franko engine.  compound built in the works
Reply #4November 06, 2010, 04:47:15 am
carrizog60
  • 978
« Reply #4 on: November 06, 2010, 04:47:15 am »
why not a 1Y manifold?
i have one on my passat 1.9td and is less work involved...
Portugal
Reply #5November 06, 2010, 09:04:53 pm
gldgti
  • 488
« Reply #5 on: November 06, 2010, 09:04:53 pm »
1y manifold would be nice, but none in australia - want to find one ofr me and post it to me?
