Author Topic: TD build - 1.6 vs 1.9 head + turbo help needed  (Read 2177 times)
November 02, 2010, 04:16:33 pm
funkaholik
  • 88
    • http://funkaholik.tripod.com/index.html
« on: November 02, 2010, 04:16:33 pm »
Hi all,
Need to build up the 1.6TD sitting in my garage ASAP, as the old engine in the car I just bought is really tired. (Car itself is great & I got it for a song!)
Questions:
Is it worth the expense to buy a 1.9 head rather than the 1.6 head that I have here that's free?  Can I really expect enough more power to justify the cost?
Or, would that $$ be better spent elsewhere?
Anyone have suggestions on who to get a nice T3/T4 hybrid turbo from?  There is a KKK on there now.
Any help & advice appreciated...
Thank you!!
Erik Miller
1981 VW Caddy - 1.6TD
2005 Infiniti G35 - Vortech supercharged, drinking E85
1967 Mustang - 390 4 speed - for sunny days
1970 Datsun SPL311 Roadster - hibernating...
Reply #1November 02, 2010, 06:26:46 pm
GEE-BEE
  • 1604
Re: TD build - 1.6 vs 1.9 head + turbo help needed
« Reply #1 on: November 02, 2010, 06:26:46 pm »
keep the 1.9 aaz head, manifold, aaz exhaust manifold and do a hybrid KO3
If it's free ?
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2November 03, 2010, 03:43:33 pm
funkaholik
  • 88
« Reply #2 on: November 03, 2010, 03:43:33 pm »
I have the 1.6 head - free.  I would have to buy a 1.9 AAZ head & am wondering if the power numbers are significantly better to justify the expense when I have a perfectly good 1.6 head here already.
Please weigh in with advice!  Let's hear your experience.
Thanks!
Erik Miller
Reply #3November 03, 2010, 05:25:32 pm
rallydiesel
  • 1880
« Reply #3 on: November 03, 2010, 05:25:32 pm »
Not if all you are doing is putting on the 1.9 head. You will have tougher cold starts and the timing will be different than "normal". If you are going to be building up the engine, than the 1.9 head would be good. However, if you are planning on a hi performance build, you should deal with the head while it's off the car, ie. port and possibly source larger valves. Otherwise, the 1.6 head is what you should stick with.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
