Author Topic: Crankshaft nose upgrade/repair tool  (Read 21181 times)
October 29, 2010, 03:31:47 pm
ilikevwdiesel
  • 1202
« on: October 29, 2010, 03:31:47 pm »
UPDATE: see at the bottom of this post!
A machinist friend of mine has designed and fabricated a tool to cut the nose of your VW diesel crankshaft so it will accept the TDI style pulley. Here is a pic of the prototype:
I used this tool today and it works excellent. Just torque the tool onto the end of the crank with the pulley bolt, put some cutting oil on the broach, and gently tap it thru. It's really slick. I used it on an engine that was on the floor but it should work fine with the engine installed as well.
 In the next couple weeks the machinist will do a production run of a dozen or so of these and they will be available for sale or you can rent one for a period if you like. This thread will be updated as the tools become available.  ;D
UPDATE: I just used the tool again, this time on an AAZ crank (the one pictured above is a 1.6 TD core I had kicking around). This crank had to be removed from the engine because somehow it had almost 2mm of taper on the face of the crank snout. A local machinist welded the nose and re-squared the face. After reinstalling the crank I cut the slot with the tool and it's all better. This thing is the bomb. We should have a cost for the tool in the next week or so.
« Last Edit: October 31, 2010, 12:51:50 pm by ilikevwdiesel »
My Bio
Reply #1October 29, 2010, 04:16:39 pm
Re: Crankshaft nose upgrade/repair tool
« Reply #1 on: October 29, 2010, 04:16:39 pm »
That looks just like Andrew's link in his sig line.
Reply #2October 29, 2010, 04:41:30 pm
ilikevwdiesel
  • 1202
« Reply #2 on: October 29, 2010, 04:41:30 pm »
Are you saying this is an imitation of the distinguished gentleman from Flagstaff's crank mod tool? I think not...it's an EMULATION
check with your legal team. :-*
« Last Edit: October 29, 2010, 04:54:52 pm by ilikevwdiesel »
My Bio
Reply #3October 29, 2010, 06:27:30 pm
Quantum TD
  • 1195
« Reply #3 on: October 29, 2010, 06:27:30 pm »
Me rents now!
Reply #4October 30, 2010, 07:01:28 am
GEE-BEE
  • 1604
« Reply #4 on: October 30, 2010, 07:01:28 am »
Either way Iam in
This would be a great gift for my local shop here in southern calif
It would be great if there was a list of shop's that had the tool so owners could have this mod done
Let me know ?
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5October 30, 2010, 07:14:14 am
rallydiesel
  • 1880
« Reply #5 on: October 30, 2010, 07:14:14 am »
That's awesome that your making it available for sale/rent!
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #6October 30, 2010, 08:23:06 am
« Reply #6 on: October 30, 2010, 08:23:06 am »
BTW
I can source the broach if need be. I don't sell alot of tooling, as I am more into woodworking shops, but I am a salesman that can usually get a deal on stuff. All I know about the broach is that it should be very expensive. I only sold one and it was 250.00 to my customer. :o
Reply #7October 30, 2010, 08:36:19 am
CdnVWJunkie
  • 309
« Reply #7 on: October 30, 2010, 08:36:19 am »
I'm def. interested in one.  Any ideas on cost?
Reply #8October 30, 2010, 09:16:50 pm
sawedoffgolf
  • 213
« Reply #8 on: October 30, 2010, 09:16:50 pm »
Do you have a price in mind to buy the tool for? i will take one if it is reasonable.
Reply #9October 31, 2010, 08:19:42 pm
starrd
  • 128
« Reply #9 on: October 31, 2010, 08:19:42 pm »
Me too, depending on price
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #10October 31, 2010, 09:55:44 pm
ToddA1
  • 434
« Reply #10 on: October 31, 2010, 09:55:44 pm »
So cool....  curious what the price will be.
-Todd
Reply #11November 01, 2010, 12:04:46 pm
ilikevwdiesel
  • 1202
« Reply #11 on: November 01, 2010, 12:04:46 pm »
You can true up the face of the crank by pulling the cam to eliminate the possibility of valve/piston contact and then running the starter while grinding the face of crank nose.
Do you have a jig to do this? How do you keep it true? With this unit there was no way to get around welding it, the timing belt was rubbing on the inside of the crank pulley and the alt belt hit the lower timing cover. It was JACKED. There should be several of these tools for sale by the middle of Nov, hopefully a price sooner.
« Last Edit: November 01, 2010, 04:28:17 pm by ilikevwdiesel »
My Bio
Reply #12November 01, 2010, 06:07:14 pm
ilikevwdiesel
  • 1202
« Reply #12 on: November 01, 2010, 06:07:14 pm »
I wonder if there's some kind of end mill cutter that would slip over the nose of the crank and keep it straight while the motor spins over? I am going to the machine tool supply and look.
My Bio
Reply #13November 02, 2010, 10:35:48 pm
starrd
  • 128
« Reply #13 on: November 02, 2010, 10:35:48 pm »
Will you be including the broach with your offering?  What size did you use in your design?
Reply #14November 03, 2010, 03:28:44 am
ilikevwdiesel
  • 1202
« Reply #14 on: November 03, 2010, 03:28:44 am »
I'll only supply a broach if we decide to rent the tool out (not 100% sure about that part yet). If someone is going to buy one of the tools they might as well source the broach themselves from McMaster Carr or some company that sells online. The broach in the pics is 6mm I believe, I didn't buy it my friend did.
My Bio
