Author Topic: question lda vs altitude compensator  (Read 1860 times)
October 29, 2010, 02:23:45 pm
derekp
  • 94
« on: October 29, 2010, 02:23:45 pm »
I'd just put a junkyard pump off a NA onto my eco diesel. I also had a turbo pump that turned out to be no good.
Im curious as to the differences between the spaceship on an NA vs on a turbo.
It seems to me (externally anyway) that the only diff is which port is vented (tho in NA both are)
So I plumbed the turbo pressure tap into the top of my lda and put the vent onto the lower port.
Is there a different spring or plunger in the NA vs the turbo ??
Havent run a full tank of fuel thru the car yet or seen any diff in the way the car runs.
(old pump leaked - hence the swap)
thanks!
The fleet
92 eco diesel (my driver turned project)
94 suburban (mine)
69 Chevelle 327 w/hillborn - resting nicely
89 Jetta coupe (sons 16v ABA head swap w/turbo and megasquirt - not run yet)
2000 jetta (other sons)
98 jetta (daughters)
2001 jetta tdi (girlfriends)
03 subaru outback (girlfrie
