Author Topic: LUK Clutches  (Read 2359 times)
October 27, 2010, 06:52:05 am
ein bora
  • 377
LUK Clutches
« on: October 27, 2010, 06:52:05 am »
I'm looking at buying a new clutch kit for my 94 jetta - 1.9 IDI as I'm getting ready for a complete engine rebuild during the winter. Can't seem to find a part number from LUK for the 94 jetta's, only the 94 golf's. Seems like 1996 is the earliest I can find for the jetta, and it appears to be for the TDI's. So subsequently both part numbers are different - would anybody know which one will work without having to take the transmission apart??
1994 golf = 17-062
Outside Diameter 8 1/4"
Spline 13/16"
Teeth 24
1996 jetta = 17-034
Outside Diameter 9"
Spline 7/8"
Teeth 28
Also - are Sach clutch kits any good as they seem use the same part numbers for all the 1.9's including the 96 TDI's
But somehow I remember reading on here someplace that they had some inherent problems.
I'm confused - any help appreciated. Thanks.
If you can't take advice - then you can't be helped!
Reply #1October 27, 2010, 07:30:57 am
MJF
  • 581
Re: LUK Clutches
« Reply #1 on: October 27, 2010, 07:30:57 am »
The Golf clutch is for 020 = IDI
Jetta clutch is for 02A =TDI
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #2October 27, 2010, 11:07:25 am
Quantum TD
  • 1195
Re: LUK Clutches
« Reply #2 on: October 27, 2010, 11:07:25 am »
02A is a cable-shift transmission.
The 020 is a linkage transmission.
Looks like LUK may not make a kit for your car.
Sachs reputation has gone down the toilet in recent years. I'll never buy another Boge/Sach shock as long as I live.
The clutch kits however, still seem to be good quality. The last one I bought (over the summer) was for a VR6 GTI. It was made in Germany, although the box said Chech republic. But, I can't speak to whatever they're making now. And, the Sachs flywheel I bought from them was made in China and was an absolute piece of $hit.
Here's my commentary on the topic on another site:
http://forums.vwvortex.com/showthread.php?4898920-If-you-think-you-need-a-new-flywheel-think-about-this...&highlight=sachs
http://forums.vwvortex.com/showthread.php?4898911-Before-you-consider-converting-to-single-mass-flywheel...&highlight=sachs
http://forums.vwvortex.com/showthread.php?4898915-If-you-think-you-need-a-new-flywheel-think-about-this...&highlight=sachs
Reply #3October 27, 2010, 05:17:26 pm
mystery3
  • 774
Re: LUK Clutches
« Reply #3 on: October 27, 2010, 05:17:26 pm »
I've had sachs clutches that lasted fine under abusive conditions in bmws but I blew one up in about 6000 miles in the caddy-1.6 n/a FWIW.
Reply #4October 28, 2010, 09:59:47 am
Re: LUK Clutches
« Reply #4 on: October 28, 2010, 09:59:47 am »
i used to run TONS of sachs super set chutches.. toyotas, vws, chevys, everything.. that was the cheapest clutches i could get.
