Author Topic: question about turbos  (Read 2827 times)
October 20, 2010, 06:10:45 am
ilikevwdiesel
  • 1202
« on: October 20, 2010, 06:10:45 am »
maybe this is a dumb question but here goes. I have a 1.9 TD upside down on a stand in my garage with the oil pan off. After sitting overnite there's a small puddle of oil on the floor below the K03 turbo, it leaked out of it thru the fan shaft on the hot side. It makes me think the turbo needs rebuilding as a seal is probably bad. anyone have any helpful comments on this? Apparently it was the oil left in the return line to the block.
« Last Edit: October 20, 2010, 06:32:14 am by ilikevwdiesel »
My Bio
Reply #1October 20, 2010, 07:43:43 am
GEE-BEE
  • 1604
Re: question about turbos
« Reply #1 on: October 20, 2010, 07:43:43 am »
call gpopshop.com
jerry..
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2October 20, 2010, 07:51:39 am
« Reply #2 on: October 20, 2010, 07:51:39 am »
I would think the way the seals work if there is no place for the oil to drain it will leak. Even with new seals. Overnight would probably be long enough to do it. If you have the chance you could spin the oil pump and see if it flies out.
Reply #3October 20, 2010, 08:30:48 am
arnold
« Reply #3 on: October 20, 2010, 08:30:48 am »
Could it be that oil got past the piston rings,and went through an open exhoust valve into the turbo ?
Reply #4October 20, 2010, 09:46:37 am
ilikevwdiesel
  • 1202
« Reply #4 on: October 20, 2010, 09:46:37 am »
If inverted they will leak profusely.  That is normal.
Andrew Rules. Next time I pass thru Flag I'm taking you for some entertainment at the local gentleman's club.
« Last Edit: October 20, 2010, 10:24:36 am by ilikevwdiesel »
My Bio
Reply #5October 20, 2010, 11:15:05 am
ilikevwdiesel
  • 1202
« Reply #5 on: October 20, 2010, 11:15:05 am »
There's something funny about that considering you sold me a small buffer stripper.   ;D
don't try to figure it out bro just accept it before it destroys you...
My Bio
