Author Topic: my 1.9 na intake update  (Read 4304 times)
October 14, 2010, 04:05:20 pm
  • 1739
« on: October 14, 2010, 04:05:20 pm »
So i finally installed the proper 1Y intake for my 1.9 na instead of the welded/modified CX style 1.7 intake/air filter that i had to use until i found the 1Y [got it from Poland no less!] . Hooked it up to a Donaldson air filter . The whole thing has 2.5 " pipes from the start of the air filter to the intake inlet. I would say i now have another 5-10 % more mid range torque- much easier to keep speed on hills- if any of you have ever driven a stock diesel Vanagon, you know how that is. Next step is to hook up the intake snorkel to the inlet of the air filter. Problem is that there really isn't much room to fit anything now because the air filter fills almost all the space at the bottom of the d pillar. I need to find some very flexible water proof  2.5 " hose- anybody have any ideas? Someone i got in touch has an Audi 80 exhaust manifold and downpipe so i can get the exhaust from the 2" to 2.5".
Reply #1October 21, 2010, 06:36:46 am
GEE-BEE
  • 1604
Re: my 1.9 na intake update
« Reply #1 on: October 21, 2010, 06:36:46 am »
CAT OR SCEET
AIRCRAFTSPRUCE.COM
CAT COLD AIR SINGLE PLY
SCEET, DOUBLE PLY, HIGH TEMP
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2October 21, 2010, 07:34:34 am
  • 1739
« Reply #2 on: October 21, 2010, 07:34:34 am »
Beautiful ! just ordered 3 feet . Thanks
Reply #3October 21, 2010, 01:10:09 pm
Wayland
  • 364
« Reply #3 on: October 21, 2010, 01:10:09 pm »
Sorry to hack, but is that a extra bit of padding/insulation over the engine area? Did you install it yourself? If so, did it make a big difference?
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #4October 21, 2010, 01:52:02 pm
  • 1739
« Reply #4 on: October 21, 2010, 01:52:02 pm »
Do you around the engine opening? If so, its part of the aluminum frame/plywood additions that came with the truck . A lot of the ex german army Transporters came like that. In the center section along the floor and l/s wall it had thick aluminum rails in which t bolts where used to brace and mount equipment. I left the ones on the l/s wall to make the body that much stronger and safer for my passengers. On top of the engine compartment were the same rails, but with plywood between them, i guess to level out the surface. It helps alittle with the sound level, but not enough!
Reply #5October 22, 2010, 09:00:28 pm
Wayland
  • 364
« Reply #5 on: October 22, 2010, 09:00:28 pm »
I hear you! I just picked up a German imported 88 TD Transporter here on the West Coast. At 100 kmh or anything over it sounds like the motor is about to jump into the back seat!
93 Dodge CTD Truck
Reply #6October 23, 2010, 08:19:43 am
  • 1739
« Reply #6 on: October 23, 2010, 08:19:43 am »
Do you know which transmission you have? It's possible you have one with  5.5 R&P. Some syncros came with an even shorter one ! I replaced mine with a 4.86, but i'm almost to the point that that i have enough power to use a 4.57, or at least a taller 5th.
Reply #7October 23, 2010, 08:39:36 am
GEE-BEE
  • 1604
« Reply #7 on: October 23, 2010, 08:39:36 am »
tyrap's on intake connector's  ?
no , no
Advise your o.d. and I will mail some silicone lined clamp's
I make a complete vanagon silicone hose kit for that
it can be seen either at Vancafe ( tiico) or at greaseworks.com
One piece design, various color's
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #8October 23, 2010, 10:07:15 am
Wayland
  • 364
« Reply #8 on: October 23, 2010, 10:07:15 am »
Yes, I definitely have a 5.5 RP.
93 Dodge CTD Truck
Reply #9October 23, 2010, 11:32:20 am
  • 1739
« Reply #9 on: October 23, 2010, 11:32:20 am »
no , no
GB
They are only temporary until it gets finalised.
Reply #10October 23, 2010, 11:33:37 am
  • 1739
« Reply #10 on: October 23, 2010, 11:33:37 am »
Do you have a tach? it's turning 3600 rpms at 88kph !
Reply #11October 23, 2010, 11:43:25 am
Wayland
  • 364
« Reply #11 on: October 23, 2010, 11:43:25 am »
No tach, but I believe it!
93 Dodge CTD Truck
