Author Topic: Best way to quiet your IDI!  (Read 3241 times)
October 09, 2010, 12:05:14 am
  • 3468
    • McScrubbins Body Wash
« on: October 09, 2010, 12:05:14 am »
I replaced all my lifters and HOLY is it ever quiet!
Just thought i'd share that with everyone.
Such a massive difference... what i thought was injector noise was lifter noise.
what i thought was lifter noise was lifter noise.
what i thought was diesel combustion noise was mostly lifter noise!!!
Reply #1October 09, 2010, 12:08:03 am
Re: Best way to quiet your IDI!
« Reply #1 on: October 09, 2010, 12:08:03 am »
lifters get super loud. my 1.8 gasser sounded almost as rattley as my diesel before i changed the cam and lifters.. then it got almost silent.
Reply #2October 09, 2010, 03:08:36 am
hooper
  • 14
« Reply #2 on: October 09, 2010, 03:08:36 am »
been thinking of doing this as mine seems a little over noisy(could be fine as im used to more modern diesels) and what i assumed was diesel knock seems unaffected by timing adjustments. i put it down to an injector issue as the engine had been stood for 7 years b4 i got it but maybe theres some tappet noise lurking there somewhere. ive had the rocker cover off to check the camshaft and theres no visible wear to anything.
Reply #3October 09, 2010, 08:41:46 am
GEE-BEE
  • 1604
« Reply #3 on: October 09, 2010, 08:41:46 am »
same here after a new complete head assy....
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
