Author Topic: Intercooler Install , VW Rabbit Truck MKI  (Read 14923 times)
October 03, 2010, 08:23:12 pm
GEE-BEE
  • 1604
« on: October 03, 2010, 08:23:12 pm »
I wanted to relocate my battery to under the bed or behind the passenger seat for room for a intercooler install
I purchased a CNC Optima mount and Battery and rotated the cnc mount 90 degrees and now the battery fits sideways with  plenty of
room for the two 90 degree elbows on each side of the 675 mm MKII radiator swap.
Installation parts : a PD130 with a 2' tubes and will have a custom Bell intercooler make a 2' thick custom intercooler
( I will advise a bell part # later )
Size ( intercooler )will be 2' outlets , 2 thick x 26 wide x 8 depth , Iam going to send them a stock radiator for them to use the stock condenser a/c mounts.
I will finish the install after the tube bead roller arrives and the upper and lower 1.6 Td  coolant hose and the the scirocco lower coolant radiator hose is finished from production.
I am using a MKII fan and I will install a dash switch to turn on for long pull's, I did have to find a fan MKII harness and a new temp sensor for the radiator( three pin)
WANT A PIC ?
Contact me at [email protected]
« Last Edit: December 08, 2010, 03:28:05 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1October 04, 2010, 08:40:57 pm
Baron VonZeppelin
Re: Intercooler Install ( Battery Relocation) VW Rabbit Truck MKI
« Reply #1 on: October 04, 2010, 08:40:57 pm »
Sounds like great ideas and excellent concepts all the way through.
Should be a KilleR set-up.
Reply #2October 05, 2010, 10:35:20 am
punkvideo81
  • 168
« Reply #2 on: October 05, 2010, 10:35:20 am »
Sounds cool. I heard someone here mention installing their battery under the bed
'81 Caddy 1.6 TD
Reply #3October 11, 2010, 08:41:36 am
« Reply #3 on: October 11, 2010, 08:41:36 am »
Post up a pic man!!
Reply #4October 11, 2010, 08:45:15 am
« Reply #4 on: October 11, 2010, 08:45:15 am »
sounds good, but what if you want a/c? Also, when this is done is there a possibility of group buy for price or is it just going to be bad no matter what  ;)
Reply #5October 11, 2010, 04:51:55 pm
GEE-BEE
  • 1604
« Reply #5 on: October 11, 2010, 04:51:55 pm »
BELLINTERCOOLER.COM Will build what ever you need, a  large 1-1/2 thick  this will work with a a/c condenser also.
Gee-Bee
I wil post part # and price when they have it
Giles Pump OHC
MK1 JETTA DASH
Reply #6October 14, 2010, 12:06:30 pm
GEE-BEE
  • 1604
« Reply #6 on: October 14, 2010, 12:06:30 pm »
ref: a/c Condenser
You can just piggy back them
They can also make a 1-1/2 thick also
New 675mm radiator sent today
Stay in touch and dont change that Dial.....
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #7October 22, 2010, 05:08:38 am
  • 3468
    • McScrubbins Body Wash
« Reply #7 on: October 22, 2010, 05:08:38 am »
Gee-Bee, i want a comprehensive thread of mostly pictures of your Porsche and your Caddy.
Reply #8October 23, 2010, 08:41:06 am
GEE-BEE
  • 1604
« Reply #8 on: October 23, 2010, 08:41:06 am »
email me at [email protected]
I have some girl's with silicone also...
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #9October 25, 2010, 08:23:52 am
GEE-BEE
  • 1604
« Reply #9 on: October 25, 2010, 08:23:52 am »
Spoke with bell today , they are going to add a cross bracce on the intercooler mount to attach to the 6 mm screws on the radiator tank's
I was informed that the outlets can be ordered in 2', 2'25 or 2'50 at the time of order
He will give me a correct size based on CFM's and the psi/hp we need
My outlet's will be two inch, one one on each side, towards the upper part of the intercooler
My tubing will be 2' ( black)red coupler's to match my coolant / radiator hoses..
Iam finishing all of my tubing, still waiting for beader before my tubing goes to powdercoat ( black)
My PD130 and race pipe will probly be just polished
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #10November 16, 2010, 10:07:43 pm
79rabbit4dr
« Reply #10 on: November 16, 2010, 10:07:43 pm »
X2!!!  ;D
Reply #11December 11, 2010, 02:34:22 pm
Re: Intercooler Install , VW Rabbit Truck MKI
« Reply #11 on: December 11, 2010, 02:34:22 pm »
Reply #12December 11, 2010, 06:39:21 pm
mystery3
  • 774
« Reply #12 on: December 11, 2010, 06:39:21 pm »
What's the difference between the rocco lower rad hose and mk1? Is it any longer?
Reply #13December 11, 2010, 06:52:40 pm
« Reply #13 on: December 11, 2010, 06:52:40 pm »
The way Komifornia is headed with marriage it won't be long until you can marry that thing. From what i have heard is out there the IC would not be a bad choice IMHO. That is amazing.
Reply #14December 11, 2010, 09:53:27 pm
mystery3
  • 774
« Reply #14 on: December 11, 2010, 09:53:27 pm »
Gee-Bee is from Orange County, it does not get more evangelical or right wing than that. Besides what's your point?
