Author Topic: Passat powersteering pump  (Read 2249 times)
December 27, 2005, 06:07:39 am
soslow
  • 15
« on: December 27, 2005, 06:07:39 am »
Do these pumps interchange with any other vw  Thanks
Reply #1December 27, 2005, 07:29:37 am
NOTORIOUS VR
  • 83
« Reply #1 on: December 27, 2005, 07:29:37 am »
If it's from a 4cyl... it's quite possible yes... even tho it might be a newer style pump, you  might have to change over the fittings from the old pump...
Reply #2December 27, 2005, 04:03:09 pm
soslow
  • 15
power steering
« Reply #2 on: December 27, 2005, 04:03:09 pm »
Sorry all it is a 1.9 td
Reply #3December 28, 2005, 05:55:55 am
NOTORIOUS VR
  • 83
« Reply #3 on: December 28, 2005, 05:55:55 am »
that is still a 4cyl... so again... I would say yes.. but you'll have to check... some of the fittings might be different, and would have to be swapped to the newer pump from the old one on u'r car at this time.
Reply #4January 01, 2006, 07:01:58 pm
soslow
  • 15
p steering
« Reply #4 on: January 01, 2006, 07:01:58 pm »
Pump off older golf was used ,return line slightly different ,pulley depth was problem. 2 pulleys bolted together solved that, all is well. Thanks
