Author Topic: Hybrid pump build in the small hours  (Read 2922 times)
September 08, 2010, 03:34:17 am
regcheeseman
  • 714
« on: September 08, 2010, 03:34:17 am »
With the current rainfall situation the paint's on hold so I'm getting on with the motor, more specifcally the injection pump.
I was up until nearly 3am building it last night, basically it's a late AAZ (rubbish spec) pump body with a TDI pump head.
The TDI pump head is only a 10 mm one - thanks to a lying git of an ebay seller 'sorry did I say 11, oh I meant 10, does it matter?????'  -  ::).
I'm using the AAZ camplate to keep the TD fuel profile. It took several goes to get the pump head on without a component falling out of place before getting the head in place, but finally I got it fitted  :) before realising I hadn't swapped the o-ring seal for a new one   >:( - the pump was fine with no leaks previously, but sods law say's it'll leak unless I change it, so I had to take the pump head off again. Seal swapped and it went back on easily, as I had had some practice by this point!
There's a accelerator limit plate on the late AAZ - that was binned
The GOV got modded and the main spring swapped for one stronger than the weedy AAZ one - think I swapping in a 1.6 or a early AAZ/1Z spring
Fitting the LDA up (after spending 40 min's trying to find the 2 LDA diaphragms that I had carefully stored months ago) and I noticed that even on full accelerator the LDA pin wasn't even coming into play and that the external accelerator lever stop was set well short of max; a quick fiddle and the LDA is pin is now visible when max accelarator pedal is used.
When I got the pump the pulley was loose - so I didn't know where to refit it.  ??? Am I correct that port A is injector 1 and that the key slot in the pump nose is aligned with the port A when the pump is locked up. i.e the woodruff key slot roughly matches the port that is currently being used by the pump head?
As per some excellent advice on here  ;)  I'm going to set up the pre lift at 1.15mm as a base setting. and this is where more fun and games began....
My DTI adaptor was too small 7mm adaptor - 8mm pump head fitting, so I checked my tool catalogue for another adaptor, then realised that the injection sensor I need to use also doesn't fit, could I swap the fitting in the centre of the pump? The 3 faced, specialist tools required one! - there's no tool available in my catalogues???
I dug through my spanners and nothing fits, I then tried my weird spanners box and found an old 9/16 whitworth fits just fine, (not a regular spanner in the all metric UK - thankfully I was brought up on triumph motorbikes and inherited a selection of old tools)
I had to remove the port valves to get access but the fitting was a straight swap for one from and old 1.6 TD pump. Hurrah!  ;D
Interestingly I noted that the TDI camplate seems identical to the AAZ one, I only had a quick look but the lift seemed similar, very similar to a GTD one, however the 1.6TD one I also have is pitiful in comparision.
I've now got to start on the cosmetics and get it looking worthy of my engine bay, but it shouldn't be far away from getting a cam belt on my motor....mind you the sun is out and I need to paint before winter hits....
Reply #1September 08, 2010, 03:58:34 am
Mark(The Miser)UK
  • 1557
Re: Hybrid pump build in the small hours
« Reply #1 on: September 08, 2010, 03:58:34 am »
So you didn't get to bed until the wife finished snoring? ;D Always keep a stock of Whtworth, they fit the injector bodies tightly too. Collected a bunch of BA taps, dies & spanners for myold Briggs  & Stratton stuff. BA12 is my limit, as I can't see any smaller  ;D
Reg, do you recall off hand, what the GTD cam lift, and bore figures were? I thought the higher lift was prone to float :-\
Mark-The-Miser-UK
Reply #2September 24, 2010, 05:11:33 am
carrizog60
  • 978
« Reply #2 on: September 24, 2010, 05:11:33 am »
and would a 1.6 pump work with 10mm head but with 1.6 cam?
i have the head,but not the 1.9 cam...
Portugal
Reply #3September 28, 2010, 08:16:27 am
regcheeseman
  • 714
« Reply #3 on: September 28, 2010, 08:16:27 am »
Just about done, need to polish that LDA top a bit more.
Lot's of cleaning, rubbing down, spraying, polishing to get to this stage
Reply #4September 28, 2010, 08:40:09 am
dts67
  • 68
« Reply #4 on: September 28, 2010, 08:40:09 am »
Would you not get a better aneroid top like a rover/peugeot with the adjuster? nice work on the cleaning what tool was used for this, a dremel?
Reply #5September 28, 2010, 12:51:38 pm
bigash
  • 14
« Reply #5 on: September 28, 2010, 12:51:38 pm »
Mmmmm that looks nice. Send it to me...Ill test it for you! ;D
Reply #6September 28, 2010, 02:49:31 pm
regcheeseman
  • 714
« Reply #6 on: September 28, 2010, 02:49:31 pm »
I was thinking of fitting a preload screw (smoke screw) but it's not a great solution as it preloads the spring and affects the linearity of boost enrichment.
I used a selection of wire brushes and a scraper to get it clean - took ages.
