Author Topic: 93 AAZ flywheel size  (Read 3886 times)
September 05, 2010, 12:10:54 am
Thezorn
  • 381
« on: September 05, 2010, 12:10:54 am »
What size flywheel do these come with stock? is it a 210mm?
Also what is the best type of clutch kit for this car. Im looking for a stage 2 im guessing.
Im running a stock pump with the fuel screw turned in, cold air intake, and will have an intercooler on it (once I can find time to put it on) and im running 15 pounds of boost right now. Im probabley going to up it to 20 with the intercooler. Right now this set up spins my clutch fairly easiley so it is definatley time for an upgrade.
Compounded 93 AAZ
Reply #1September 05, 2010, 12:29:29 am
vanagonturbo
  • 639
    • Fine Tuning
Re: 93 AAZ flywheel size
« Reply #1 on: September 05, 2010, 12:29:29 am »
Do you have a cable shift trans or linkage?
Reply #2September 05, 2010, 08:55:53 am
« Reply #2 on: September 05, 2010, 08:55:53 am »
its gonna be 210 if its an 020 trans, and 228mm if its an 02A
but im not aware of a 93 vw diesel that uses a 02A..
Reply #3September 05, 2010, 06:37:35 pm
Thezorn
  • 381
« Reply #3 on: September 05, 2010, 06:37:35 pm »
Its gotta be an 020 then. So that means 210mm
Now as for a clutch, what should I be looking for.
Should I be looking for a Stage 2 clutch out of a VR6 1.8L or a 2.0L?
Im guessing the VR6 stage two would be the strongest, but what is the best bet?
Compounded 93 AAZ
Reply #4September 05, 2010, 08:45:53 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #4 on: September 05, 2010, 08:45:53 pm »
You cannot use the VR6 clutch. It is only for the 02a trans. With your current setup, you should use a stock 210mm disk with an upgraded pressure plate. I recommend the ACT pressure plate.
Reply #5September 06, 2010, 03:37:05 am
« Reply #5 on: September 06, 2010, 03:37:05 am »
Passats are diesel and 02a starting in 92 iirc
Reply #6September 06, 2010, 09:03:57 am
« Reply #6 on: September 06, 2010, 09:03:57 am »
At least in Canada, eh??!!   ;)
(In North America) Canadian Passats seemed to be the test bed for stuff that showed up later on Golfs and Jettas but you never know who has swapped what into what... best bet OP is to check to top of the transmission to see if you have cables or rigid shift linkages.
« Last Edit: September 06, 2010, 09:12:22 am by Vincent Waldon »
Reply #7September 06, 2010, 09:10:24 am
1outof5
« Reply #7 on: September 06, 2010, 09:10:24 am »
I had a 1991 "eco" AAZ passat with a cable shift trans
Reply #8September 06, 2010, 09:50:01 am
« Reply #8 on: September 06, 2010, 09:50:01 am »
ok, well i stand corrected, but most of the pre-93 diesels were stuck in canada. there are not many passat diesels here.
Reply #9September 06, 2010, 07:16:00 pm
Thezorn
  • 381
« Reply #9 on: September 06, 2010, 07:16:00 pm »
sorry I thought I mentioned that. It is "shifter linkages" but I wouldn't goas far as calling them RIDGID since it need a good rebuild kit haha.
Compounded 93 AAZ
