S-PAutomotive.com
Author Topic: I guess now's a good time to put in the bolt kit  (Read 2770 times)
September 04, 2010, 07:13:58 pm
rallydiesel
  • 1880
« on: September 04, 2010, 07:13:58 pm »
 :o
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1September 04, 2010, 11:57:19 pm
  • 7834
Re: I guess now's a good time to put in the bolt kit
« Reply #1 on: September 04, 2010, 11:57:19 pm »
It is the perfect time.
Wouldn't hurt to clean it a little too  ;D
Reply #2September 05, 2010, 09:50:36 am
GEE-BEE
  • 1604
« Reply #2 on: September 05, 2010, 09:50:36 am »
I picked up my other from the powdercoater and i purchased a ext ARP bolt kit for it, peloquin is sitting in the box, I will try to do the flanges and Clutch arm in a different shade..
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3September 05, 2010, 11:29:48 am
  • 7834
« Reply #3 on: September 05, 2010, 11:29:48 am »
doesn't the peloquin kit come with the ARP bolts? If so you may have an extra kit to sell. If not you will still be prepared.
Reply #4September 05, 2010, 02:25:37 pm
rallydiesel
  • 1880
« Reply #4 on: September 05, 2010, 02:25:37 pm »
Drilled out one ring gear. I'm surprised the rivets fail. They are quite beefy. I went through more than one drill bit getting them out. The trans magnet was covered in sludge but the gears and syncros actually look pretty good.
Reply #5September 06, 2010, 05:30:56 pm
GEE-BEE
  • 1604
« Reply #5 on: September 06, 2010, 05:30:56 pm »
I also got all the external bolt's from ARP (Cases )
Polished s/s 12 Point
OCD is my middle name...
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #6September 06, 2010, 06:18:39 pm
  • 7834
« Reply #6 on: September 06, 2010, 06:18:39 pm »
I talked to broke vw about this. He said that the earlier 020 trans had VERY hard rivots and no problems with the rivots machining the case. I think he said around 84 and up 020, but you would have to ask him for sure, were the ones with soft rivots and you would have trouble. I know all the ones 86 and after were bad according to him.
Reply #7September 07, 2010, 08:07:00 am
« Reply #7 on: September 07, 2010, 08:07:00 am »
What are you doing with that big ol`auto starter?
Reply #8September 07, 2010, 11:21:26 am
rallydiesel
  • 1880
« Reply #8 on: September 07, 2010, 11:21:26 am »
That's a new starter for my 1.6. Bought it last year. The new style does not require the starter bushing in the bellhousing.
Reply #9September 08, 2010, 04:39:54 pm
« Reply #9 on: September 08, 2010, 04:39:54 pm »
Oh, it looks huge for some reason ???
Reply #10September 26, 2010, 02:03:04 pm
« Reply #10 on: September 26, 2010, 02:03:04 pm »
looks like a normal sized unit to me. but if you sat that next to a mini-gear-reduction starter, yea, its gonna seem huge. lol.
