Author Topic: Bilstein HD.........now with review.  (Read 4770 times)
September 03, 2010, 11:06:35 pm
« on: September 03, 2010, 11:06:35 pm »
So I couldn't decide if I wanted coilovers or HD's until a little while ago a member on here helped me make up my mind. And I've been drooling over the HD's for the last year or so, comparing prices and all that, then I noticed in the description a few days ago it said that bilstein discontinued them 6/10. My heart sank, the HD assembly usually cost $135-160 (I got 'em for $137ea) while the insert cost $162-190. AND I can only find inserts that work with externally threaded struts so that would add more to the cost.
I'm hoping they'll work good with the KYB gas-a-just on the rear.
They came in today so I got to drool on 'em, they're pretty weird looking with the fat shaft and all. I'll write a big long detailed review when I get 'em installed. It'll be a little while since the current struts/shocks aren't totally shot yet.........I'll try to hit all the big bumps though ;D
« Last Edit: October 28, 2010, 10:44:57 pm by rabbitman »
Reply #1September 04, 2010, 07:54:02 am
VWCaddy
  • 85
    • VW Caddy Page
Re: Bilstein HD
« Reply #1 on: September 04, 2010, 07:54:02 am »
I love mine, been in over 10 years now and still ride like the day I installed them.  Mine came w/ internal and external tops.  No comparison to the KYBs they replaced:
- http://www.4crawler.com/VWpickup.shtml#Suspension
'82 VW pickup, 1.9D engine, Missing LinkZ shift linkage
Reply #2September 04, 2010, 03:16:01 pm
Re: Bilstein HD
« Reply #2 on: September 04, 2010, 03:16:01 pm »
That's weird, last summer I tried putting my new boge inserts in and found out they were for external threads so I was gonna just use my old tops but the whole insert is different. I think it was longer and also at the bottom is a taper that the other doesn't have.
Reply #3October 28, 2010, 10:44:06 pm
Re: Bilstein HD
« Reply #3 on: October 28, 2010, 10:44:06 pm »
Ok so I finally hit enough frost heaves and bumps to sufficiently ruin my old napa struts ;D. While smooth road is ok they got so the front would bottom and then bounce up and hit the top too easy.
So I pulled the junkers off and installed the bilsteins, I reused the top eccentric bolts and the new moog 12mm bolts, forget the 10mm ones.
Easy install as usual, I did the alignment myself kinda. I set it at about 1/2 degree of negative camber and then messed around trying to get the toe right, I think I'll take it in and get it done right since I hate wearing out tires.
Suspension setup:
The front has MK2 jetta springs with 1 1/2 coils cut off wrapped around Bilstein HD's.
In the rear it has KYB whites with variable rate springs and a stock MK1 jetta sway bar.
Prothane bushings all around, I consider these a necessity.
The ride is harsh, every tar line in the road goes BANG.....THUD and all that. Swerving back and forth is quick with a tolerable amount of body lean partly due to the heavy front springs and a lot to do with the bilsteins.
I went off-roading a few times and it takes the big bumps REALLY good...... I would brace thinking it would hit hard and bounce off the top but I was pleasantly surprised at how gentle it was, a real shocker.
I have a set of moog CC204 variable rate springs coming, I want to get rid of some of the tar-line clunking.
After feeling the superior damping of these struts I really wish I'd gotten bilsteins for the rear too.....I saved $80 by going with the KYB's. Maybe I'll put 'em on my red rabbit when I sell it, then I'll have an excuse to get bilsteins ;D.
Reply #4November 03, 2010, 09:18:08 am
Re: Bilstein HD.........now with review.
« Reply #4 on: November 03, 2010, 09:18:08 am »
You don't have a lot of weight to damper in the back.. IMO KYB Gas-A-Just are a mono-tube shock/strut.
I would get me some, but the price is a little bit outta my range ;)
Reply #5November 03, 2010, 10:28:18 am
« Reply #5 on: November 03, 2010, 10:28:18 am »
I got my KYB's on amazon for $60 apiece and free shipping :D
Reply #6November 08, 2010, 07:40:56 pm
« Reply #6 on: November 08, 2010, 07:40:56 pm »
Ok so I've since swapped out the overly hard clipped mk2 springs in the front for a set of moog CC204 variable rates. The mk2 springs were nice in that I didn't have to use a compressor to install 'em, just squish 'em by hand a little bit and put the nut on......that's how hard they where!!!!!!
The moogs on the other hand required lots of compressing, probably 5 inches.
Driving is much nicer, small bumps like tar lines are way quieter, gravel roads are slightly gentler even though it's still pretty loud.
Big, off road bumps are a pleasure to hit.......smooth with no jaring impacts. I have yet to bottom out with these.
Overall I totally recommend them.....they aren't cheap but from what I hear they last almost forever and have a good warranty in case they don't.
Reply #7November 08, 2010, 07:46:55 pm
« Reply #7 on: November 08, 2010, 07:46:55 pm »
How much were they? I think you were in Alaska so it maybe a bit more, but just for reference.
Reply #8November 08, 2010, 07:53:00 pm
« Reply #8 on: November 08, 2010, 07:53:00 pm »
55 bucks from amazon.....free shipping!!!!!! I almost wet myself when I saw 'em, I've been looking forever to find somewhere that sold 'em cheap would ship cheap.......it was UPS too :o
One thing though, they raise the front a little more than I would've liked, I think about an inch so it sit's higher up front than in the rear.
