Fixmyvw.com
Author Topic: Boost Controller  (Read 1665 times)
August 30, 2010, 06:32:40 pm
spencebm
  • 686
Boost Controller
« on: August 30, 2010, 06:32:40 pm »
What is a good one to buy?  I have tried to make one but am having trouble getting it to stay at the right boost level.  Could someone give advice on a high quality item that I can get 30-40 psi out of that isn't junk.  Thanks.
Ben Spencer
Reply #1August 31, 2010, 07:43:58 pm
UnderPSI
  • 109
Re: Boost Controller
« Reply #1 on: August 31, 2010, 07:43:58 pm »
Google DIY boost controller.
Suzuki Samurai 1.6
Reply #2August 31, 2010, 07:57:14 pm
bugnut
  • 89
« Reply #2 on: August 31, 2010, 07:57:14 pm »
If you are looking for a good one look at Turbosmart.  They have a few different ones.  I have both the manual and eboost2.  The cost is $70 for the manual boost controller and the eboost2 is around $550 depends where you look.  So far I have only used the manual on the rabbit.  I am using the eboost2 on the bug.
1980 Rabbit  1.9/1.6 franko engine.  compound built in the works
Reply #3September 01, 2010, 11:06:18 am
spencebm
  • 686
« Reply #3 on: September 01, 2010, 11:06:18 am »
I have tried the DIY approach and my design needs to hold a lot of boost, not 10 psi like most of the options out there, more like 25-30.  I am using one currently like likes to move my spring and not work anymore because it is of the home made variety.  I was just curious as to what everyone else is running because I know a lot of guys on this forum are running serious boost numbers.  Thanks for the help, too.
Ben Spencer
Fixmyvw.com
