Author Topic: Vanagon burning oil (has good compression)  (Read 7641 times)
Reply #15August 26, 2010, 07:37:49 am
stanton.samuel
  • 21
Re: Vanagon burning oil (has good compression)
« Reply #15 on: August 26, 2010, 07:37:49 am »
is that the same as a cam oil baffle? a piece that sits over the cam shaft and deflects oil away from the breather?
82 vanagon w/ original 1.6 na diesel
Reply #16August 26, 2010, 08:34:11 am
rs899
  • 647
« Reply #16 on: August 26, 2010, 08:34:11 am »
No- they are different, but you can do both.  The oil separator is a device that takes the oil-laden fumes that the engine pumps out at the top of the valve cover, sends them over to a device, spins them around and separates the lighter fumes (which go up to the intake manifold) from the condensing oil ( which is returned to your sump).
Reply #17August 26, 2010, 05:15:29 pm
stanton.samuel
  • 21
« Reply #17 on: August 26, 2010, 05:15:29 pm »
that sounds like it has potential.  Am i just putting off the inevitable though?
pulled off the breather hose while the van was running just to see, i was half expecting to see globs of oil pouring out,  the gasses leaving were smokey, but no globs of oil, i dont really know what it is supposed to look like so i'm not sure that did any good.
i'm considering a swap to a 1.9 TD AAZ but its really expensive and i would way rather just repair this engine if possible.
Reply #18August 26, 2010, 07:28:26 pm
« Reply #18 on: August 26, 2010, 07:28:26 pm »
If it wasn't dripping I bet the cam baffle will cut it down to at least 25% of what you were used to.
