Author Topic: Bad tach signal?  (Read 4571 times)
August 18, 2010, 04:55:57 am
veector
  • 95
Bad tach signal?
« on: August 18, 2010, 04:55:57 am »
Had this problem for some time now, I swapped out clusters but it didnt go away.  The rpm reads double what it should (idle just under 2000)  This causes the tach to roll past redline when i drive causing the entire cluster to shudder and reset.  any ideas what this could be?
cheers,
Vic
btw 1994 Jetta TD
1981 Jetta D
1997 Jetta TD
Reply #1August 22, 2010, 09:28:44 pm
Turftech
  • 113
Re: Bad tach signal?
« Reply #1 on: August 22, 2010, 09:28:44 pm »
I think the tach uses a signal from the alternator.  You might want to check it.
'90 Jetta GL TD  570'000 Kms and counting (Gave her to a friend)
'92 Passat G60 Syncro Wagon 180'000kms. TDI conversion project
'87 Jetta Coupe 325'000kms. MF IDI conversion project
Reply #2August 24, 2010, 05:25:33 am
veector
  • 95
« Reply #2 on: August 24, 2010, 05:25:33 am »
put a used alternator in a few months ago so I dont think thats the issue?  What could cause the tach to read double the revs?
1981 Jetta D
1997 Jetta TD
Reply #3August 24, 2010, 11:30:54 am
Settings
  • 52
    Hudson, QC
« Reply #3 on: August 24, 2010, 11:30:54 am »
I assume you have a gas tach. The signal from the alternator is essentially twice the frequency of that from the distributor (where the gas tach normally reads from).
There are several solutions provided on this forum from people much more knowledgeable than myself.
Start in the FAQ under 'Tach'  http://www.vwdiesel.net/forum/index.php?topic=16687.0
1993 AAZ Jetta ~280k
Reply #4August 25, 2010, 06:15:41 am
veector
  • 95
« Reply #4 on: August 25, 2010, 06:15:41 am »
Thing is though, I have a diesel tach, but a gas alternator.  if it makes any difference.  Il do some reading there too
cheers
vic
1981 Jetta D
1997 Jetta TD
Reply #5August 25, 2010, 11:08:06 pm
doonboggle
  • 179
« Reply #5 on: August 25, 2010, 11:08:06 pm »
Maybe this discussion will help ...
http://www.thetruckstop.us/forum/showthread.php?14489-whats-the-difference-between-diesel-and-gas-alternators
cheers,
Vic
btw 1994 Jetta TD
doonboggle
1981 Rabbit pickup; 1.6L diesel
2006 Jetta TDI
1971 VW Karman Ghia convertible
